Old 10-13-2017, 09:50 AM   #1
Nodnarb76
Nodnarb76's Avatar
Talk to me about lowering my 3/4 ton Suburban.
I have had my Suburban for a little over 4 years now.
I have already swapped a 6.0/4L80 into it last year.
I have always had in the back of my mind that I would like to lower it and put a nice set of wheels on it. I never found a set of wheels I liked though, until now. I fell in love with the Detroit steel artillery wheel.
It is not easy finding parts to lower a 3/4 ton Suburban, but after looking, Western Chassis looks like they can sell me spindles, coil springs, new rear leafs, and rear leaf shackles that will drop my Suburban about 5 1/2 inches in the front and 5 inches in the rear.
The wheels are not available in 8 lug, so I would have to get adapters, which are going to be 2" thick. They offer different offsets so I should be able to overcome the extra 2" by getting the offset correct. I haven't decided on 22" or 20" wheels yet, and would like to get opinions on what wheel size would be best.
I am worried that about 5" of drop on a 3/4 ton will not be that low and may sit only slightly lower than a stock 1/2 ton.
does anyone have pics of a suburban with a 5" drop?
any opinions or suggestions?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 10-13-2017, 09:53 AM   #2
buffydores
buffydores's Avatar
Re: Talk to me about lowering my 3/4 ton Suburban.
My opinion. I'd struggle doing anything to a ride that already looked spectacular like yours.
Old 10-13-2017, 02:43 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
Yeah ditto that. Although I like the way Hummer wheels look on C20 Burbs. But never lower it or do anything to "un-beef" it. Great truck.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-14-2017, 09:49 AM   #4
Nodnarb76
Nodnarb76's Avatar
Thank you for the kind words!
You may have talked me out of wanting to lower it.
After I weigh the pros/cons of lowering it, I may just keep it stock height and replace springs/bushings/shocks etc. with new parts.
Before my lowering plans, I had intended to go with Chrome H2 Wheels with stock 8 lug chevy center caps. Although if I do that, I would like to convert the rear to disc brakes, and use Willwood calipers and drilled rotors all the way around. I think they would look great behind the H2 wheels.
Old 10-14-2017, 08:26 PM   #5
schpeen
schpeen's Avatar
I agree 100%. I'd play with the wheels and tires instead. I've had my eye on these Hutchinson beadlocks.
1991 K5 Blazer 4x4 "9 ball"
2019 Chevy Silverado Trail Boss 4x4
2018 Chevy Colorado 2 door ZR2 4x4
1988 23' Mako Marine
2005 Harley Davidson Road King
schpeen is offline   Reply With Quote
Old 10-18-2017, 12:38 AM   #6
blazinzuk
blazinzuk's Avatar
I intend on dropping my 3/4 ton burb. But a mild drop.
As far as stock heights a 3/4 ton c is taller than a half ton k by a small amount
Eric
89 diesel jimmy
86 crew dually
87 truggy Horton
blazinzuk is offline   Reply With Quote
Old 10-18-2017, 03:58 PM   #7
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Do what you want. I wouldn't let these guys talk you out of it. I am thinking of doing it to a 3/4 ton I got recently. Here are some photoshops.I would go to a conversion spindle so you can chose from any five lug wheel and change rearend or get new axles.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
