05-29-2017, 02:24 PM | #1 |
Harmonic Bal is bad - can I test this 250 anyway?
The basic question is - Can I start and test run an engine (just inside the shop) if the HB is completely shot? What bad things might happen? I guess the HB could fly apart - maybe.
I'll need to make some basic assumptions like - I need to hope the timing is already set properly. I understand the alternator and fan pulleys will not spin properly. I just don't want to take the time to install another HB if the engine is really bad. I pulled off the rocker cover and things looked pretty clean, so I'm hoping this engine is good. Back story - I bought a 1963 Custom SBFS with BBW in January. Straightest (as far as fewest dents and dings) I've ever seen for a 60-66 original truck but more rust than most would want. All original for the most part but the engine was replaced with a 1971 250ci. I just now figured out that the rubber on the HB is completely shot. I can spin the HB outer ring by hand turning the fan. The 250ci doesn't have a bolt in the end of the crank, or I'd hand turn the crank to see if I had reasonable compression. Pics are for interest.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
05-29-2017, 02:53 PM | #2 |
Active Member
Re: Harmonic Bal is bad - can I test this 250 anyway?
If the HB outer ring is so loose you can turn it by hand, I wouldn't run the engine. I'd disconnect the distributor to coil cable and use the starter cranking to check compression. That's the normal way to check compression.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
05-29-2017, 03:40 PM | #3 | |
To do it your way, if compression checks out then it'd be worth the effort to replace the HB.
05-29-2017, 06:14 PM | #4 |
Active Member
Yeah, Lug, I agree that hearing it run would be nice.
You could try to start it by first removing the belts and outer ring itself. Just run it with inner HB but I wouldn't run it for more than a few seconds. Or, if the belt or belts are on tight they may keep the outer ring on the HB, but it's still taking a chance. Your call, I guess.
05-29-2017, 08:13 PM | #5 |
Well, you provided me with the motivation I needed. I quickly found a double groove HB I had stashed away. It came from a scrap yard 250ci. That was more than half the battle right there. The radiator was draining while I looked.
I had the old HB off in 1/2 hour. The double groove HB was on within another 40 minutes or so. I used a remote starter button to spin the engine. It seems to have great compression. Unfortunately I didn't get it started. I gave up rather quickly 'cause I'm pretty sore right now from the sunburn I got boating on the lake this morning. Tomorrow I will check to make sure I have spark. Not certain if the fuel pump works. I'll check that too. If the timing mark seems off, I'll static time it. Of course I'll check compression as well.
05-29-2017, 10:57 PM | #6 |
I woulda run it.....but not revving and only for a few seconds. lol But yes....I live life on the edge. Smart move to pop another one on.....can't wait to see if she fires!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
05-30-2017, 09:26 PM | #7 |
Watch the video. I replaced the harmonic balancer, and installed a distributor with points elimination (Accell or Pertronix - I can't remember). Thankfully I had these parts in storage. My good friend and hot rodder helped. We finished by flashlight in the shop. I love my new shop but no power in it just yet. Here's a short video. Timing has not been set yet. Stay tuned, pun intended.
VIDEO LINK
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. Last edited by Lugnutz65; 05-31-2017 at 11:16 AM. |
05-31-2017, 11:13 AM | #8 |
Looks good, maybe a freshen up on the carb and tweak in the timing you'll be in good shape. It's starting right up do i don't think timing is too far off. Keep us posted.
Paul
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!! My Build Thread: Project 72' Green http://67-72chevytrucks.com/vboard/s...d.php?t=587932 |
06-01-2017, 09:35 PM | #9 |
UPDATE:
Same carb. Timing set at 6 degrees advance. Since it has a Pertronix ignition in the dizzy, I might advance it a little more later and see. The brakes need going through. That's next. If you wanna keep up with this project, you can follow any progress HERE on my BLOG. LINK to NEW VIDEO of engine running 6/1/17. Lugnutz65
