05-16-2017, 12:52 PM | #1 |
383 questions
looking to install 383 in a 72 3/4 ton 4x4, drive on pave ment only to nice to off road, So are all 383 the same? Want one for pulling, and hot rodding. How are the 383 ht. from gm. Any other ideas. thanks Bill
05-16-2017, 08:49 PM | #2 |
Re: 383 questions
No way even close tot he same. They are all 383's but there are a load of different combos. Tires, gears, weight, trans, driving habits, the want to pull a boat will all drive what combination of parts will best suit your truck.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-16-2017, 11:27 PM | #3 |
60-66 Nut
Re: 383 questions
The HT383 is a good engine for a truck that is used as a truck such as towing.
05-22-2017, 06:35 PM | #4 |
Re: 383 questions
has any one got feed back on a ht 383 create motor, tjanks
05-22-2017, 07:18 PM | #5 |
motor exploder
Re: 383 questions
buy one and let us know how you like it . I've always been interested in the HT series, both the 383 and the 502 for a DD type engine. Seems like a good fit.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
05-23-2017, 12:44 AM | #6 |
60-66 Nut
Re: 383 questions
Several years ago, Chevy High Performance magazine ran a series of articles on the HT383 Crate engine, starting with a bone stock engine right out of the crate.
http://www.superchevy.com/how-to/578...e-engine-test/
05-23-2017, 07:06 PM | #7 |
driving is in my blood
Re: 383 questions
There ya go. Thousands of reviews. Its basically a vortec 350 stroked into a 383. Good engine.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
05-23-2017, 10:15 PM | #8 |
Re: 383 questions
I don't know anything good or bad about the HT383. I do know they are not the same as a conventionally built 383 is. Most 383's are built using a 4.030 bore and a 3.75" stroke crank. Chevy's 383's are built with a stock 350 4.000" bore and a special 3.80" crank. The pistons and crank are unique to the Chevy version.
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
