05-18-2017, 07:49 PM | #1 |
Nv3500 hyd clutch line part # wanted
Does anyone have a part # or link to a hyd clutch line for an 2006 nv3500. Photos are of my master and slave. I need a 48" line and cannot find one.
Opportunity is missed by most because it is dressed in overalls and looks like work. - Thomas Edison |
05-19-2017, 07:26 AM | #2 |
Re: Nv3500 hyd clutch line part # wanted
Do you want to keep that quick connect style fitting?
When I was researching stuff for my swap I found that the T56 and NV3500 use the same internal throwout bearing. I ordered a fitting and a line from Speedway motors and converted mine to -3AN. The fitting number for the pressure line is 5151396. The line I ordered was 36" but they have several lengths to choose from, its part number is 91031846-3. I also used a remote bleeder kit to try and keep the mess out of the bellhousing area. It worked really well, the number for it is 5151399-12. They have different lengths as well, if you want it longer or shorter. The link to my swap is in my signature if you want more details or pictures. They also sell braided lines with that quick connect end, just search for a T56 line. They run about $120 though which is why I just went with regular AN stuff. I will have to bleed it everytime I remove the trans but I dont think it will be that big of a deal as the remote bleeding kit made that really easy. edit: Heres the 48" braided line with the quick connect end. Its $110 though... http://www.speedwaymotors.com/McLeod...nch,39998.html
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 05-19-2017 at 07:31 AM. |
05-20-2017, 05:55 PM | #3 |
Alright so I bought that 48" line and it's a great fit except I cannot find a fitting to adapt it to my master cylinder. I have a Wildwood 260-6579, fitting of it is female along with female on that line.
05-20-2017, 11:32 PM | #4 |
60-66 Nut
I believe the clutch master has a 1/8" pipe thread. You will need to remove the brass fitting that is currently screwed in the port and replace it with a fitting that has 1/8" pipe on one end and -4AN male on the other end. Speedway should have those fittings as well as other suppliers.
05-21-2017, 06:58 AM | #5 |
According to the spec sheet for that master its 3/8-24 Here is a fitting to -4AN
http://www.speedwaymotors.com/3-8-In...ting,6462.html This is another option, you might need a set of washers as well. http://www.speedwaymotors.com/Earls-...ed,146452.html http://www.speedwaymotors.com/Steel-...olt,32520.html Heres a kit if you dont want to piece it together http://www.speedwaymotors.com/Banjo-...-AN,36488.html
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 05-21-2017 at 07:06 AM. |
05-21-2017, 11:59 PM | #6 |
60-66 Nut
It is best to not have too many pieces when plumbing. This is what I was talking about. Just remove the fitting that is on the master and install this:
http://www.speedwaymotors.com/Longac...ht,282719.html or this: http://www.speedwaymotors.com/Longac...g-,283168.html
05-22-2017, 07:16 AM | #7 | |
I linked him to a similar fitting first that will work in his master that is like the ones you linked. The reason I gave him the banjo bolt option is because I couldnt locate a 90* fitting when I did mine and I used the banjo bolt so the line wouldnt have to make that curve. Not trying trying to be a jerk here, I just dont want him buying something that wont work.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
05-22-2017, 09:43 AM | #8 |
I bought the first fitting (per wilwood spec sheet). We'll see if it fits correctly. I appreciate both your help locating fitting. Thanks
