08-23-2019, 01:04 PM | #1 |
Stranded in middle nowhere, 1987/350 manual ECM fuze blown
I had another fuze in the truck, plugged it in and it blew...
Any ideas to get me back on the road? Thanks! |
08-23-2019, 01:08 PM | #2 |
Old member
Re: Stranded in middle nowhere, 1987/350 manual ECM fuze blown
Sounds as if you have a straight to ground issue.
Which fuse is it?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
08-23-2019, 01:21 PM | #3 |
ECM 1 fuze
08-23-2019, 01:41 PM | #4 |
Wonder if I pull the 30 amp accessory fuze I might get lucky and it will start? Only have one fuze left
08-23-2019, 02:18 PM | #5 |
Found it after much searching, a frayed wire at the injector area.
08-23-2019, 03:54 PM | #6 |
08-23-2019, 09:45 PM | #7 | |
BMW & ASE Master Certified
if it was 30, I'd say why not... never put a larger amp fuse in place of one that's instantly blowing, your asking for a much bigger problem than you had such as a fire. even if its just to get you home... clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
08-25-2019, 11:09 PM | #8 |
Old member
Glad you found it. Sorry haven't been on the computer in a couple of days. Had no internet.
08-26-2019, 05:14 PM | #9 |
ECM 1 is a 10 amp, I was only going to pull the 30amp to see it affected the short, not use it in place of a 10 amp.
