10-10-2016, 05:56 PM | #1 |
Equal opportunity joke ofender
4th door "vent window" removal
Ok so i have never worked on 4th "door" windows before. I did a quick search but did not find anything. I am trying to remove the little window from the 4th door spot on a 72 suburban. I already have the roll down window and the regulator out but can't get the little window to budge. I just assumed it was wedged in with the rubber. What am i missing? I don't want to break it.
thanks Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
10-10-2016, 07:08 PM | #2 |
Re: 4th door "vent window" removal
This is the window I am speaking of.
10-10-2016, 08:19 PM | #3 |
Post Whore
Do you have the divider bar out? If not there is a sort of hidden screw at the top that is under the window channel felt, and 2 at the bottom of the bar that can be removed from the inside if the 2nd row seat is removed. Be careful on the top screw it will strip easily. When the divider bar screws are out the rubber is all that is holding the bar and the glass in. I used lots of soap, some nylon pry sticks, and an old flexible putty knife to get them out. One came out after 20 minutes or so, but the other one I argued with for about an hour. My thread Working Man's Burban has some more info and some photos on this at post 30 and after.
Good luck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-10-2016, 08:27 PM | #4 | |
Richard
10-10-2016, 11:57 PM | #5 |
Post Whore
I was told that a hair dryer can soften the rubber, but I have never tried it. I used the putty knife to work soap in all around the frame and glass. I would have left the seals in but the bottom on one side was so deformed you could drop a dime in inside the door.
10-11-2016, 03:55 PM | #6 | |
I changed all my seals already in the 4th door and I can still put coins down there if I want. I think it is just poorly fitting from GM. |
10-11-2016, 04:55 PM | #7 |
Post Whore
I changed all my seals already in the 4th door and I can still put coins down there if I want. I think it is just poorly fitting from GM.[/QUOTE]
It is a poor design. I have a fix in mind to make it better, but I am waiting on new seals to try it out. I will post my results.
10-15-2016, 04:35 PM | #8 |
Finally got the glass out and managed to save the gasket as well. But now my passenger door won't shut. Coincidence or maybe a body mount gave out?
10-16-2016, 12:47 AM | #9 | |
The Older Generation
LockDoc
