05-31-2003, 11:18 AM | #1 |
283 or 327?
Alright. I know the infamous Camel hump heads. But which ones are better. I know that of course the bigger heads are better for more flow. But they did come on 327's also right? But the 283 heads arent crap by any means are they? I can get a pair. Lemme know what you think.
Brandon |
05-31-2003, 11:20 AM | #2 |
I would go with the 327. i have a 327 +.30 in my C-10 and i love it. IMO
05-31-2003, 11:44 AM | #3 |
Careful, they attack...
Whether they are crap or not depends on the casting. If you get and post the casting number, we could help more. There are more than one set of camel hump heads that could be. Some are better than others, but almost all are good. Nice thick castings so you don't have to worry much about cracking. If you can get them cheap then I say go for it. Especially if they need rebuilt. Don't over spend just because they are "camel hump" heads. I had a set I gave away off my 327 years ago, and now I wish I had them back. Also, see if they have the accessory holes because you might have the short waterpump set up on your truck. So you would need the holes to mount you alternator on. Some camel backs didn't have the accessory holes in them.
Good luck |
05-31-2003, 12:09 PM | #4 |
Well. These I can just go pull off this motor. No cost involved. Just time. They do not have any accessory holes in them. I dont know what water pump I have on my truck. I do know that the truck this motor came out of, had to start the truck in 'Drive' because the shifter was broke off in the column, so it was touchy. It would turn those 31" tires over easily on accident. Hehe. Although it has a 2 bbl carb on it. .... Who knows.
Brandon |
05-31-2003, 12:11 PM | #5 |
Heres a pic of the motor with the heads
05-31-2003, 12:26 PM | #6 |
With your alt on the driver side you might need the accessory holes. How does you atl bracket attatch to the heads now? there might be a cast bottom bracket and a long arched bracket on top. I can't see it in the pic at all. If you have a bracket attatched to the heads, then you will need to find heads w/ the accessory holes or get an aftermarket bracket. If they are actually 283 heads you shold be fine, but if they are actually 327 heads with 2.02/1.6 valves you might want to be careful if they are going on your 305. A 305 has a smaller bore then a 327 or 350, and you can't use big valve heads in them very well. The valves hit the cylinder wall. A 305 has a 3.767 bore and a 327or 350 has a 4.000 bore. Just something to keep in mind. If they are the smaller and more common 1.94/1.5 heads then you should be fine.
05-31-2003, 01:12 PM | #7 |
Yes. I know these are 283 heads. I do not believe that anything attaches to these heads in the front. I dont know how the brackets attach. When I go down next week to work on my truck, I'll pull them and the valve covers. I'ma keep them for decoration as one is cracked. Hehe. Thanks bud.
Brandon |
05-31-2003, 01:26 PM | #8 |
Well its kinda a guess but I would say the pic shows a older 283-327 possibly with the short water pump... so take the bracket that holds the alternator as well I think that type uses the water pump bolt as a source to hold the bracket. The lower mount for the alternator/generator probably uses the exhaust manifold... the exhaust manifold proabably has a ear on it thats threaded... you may need that also....but you gotta check on what type exhaust you have now and if what is on this parts vehcile will fit... the ram horn on this car type probably dumps straight down... so custom exhaust work may be necessary if you have a 305 in there now, might ass well grab both exhaust manifolds.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
05-31-2003, 01:30 PM | #9 |
I guess I was typing as you were answering also... anyway.. I would say pull the whole motor if your into rebuilding something.... if not... what are those valve covers gonna cost me?.
05-31-2003, 02:27 PM | #10 |
Haha. I dont know. I kinda wanted to keep them as decoration for my garage, but I'll clean 'em up and see if they can be use to anyone. U got first dibs. lol. I do seem to remember it using part of the exhaust on the left side of the motor(lookin at it from the front) The exhaust dump at the rear. I'll just pull basically every part off that motor and keep them. :-D Then just throw the heads on my 305, keep the 4 bbl intake and carb it has now. and put on the ram horns from this motor. This 283 is sittin in a crap box Camaro. Pshh. It's not worthy. lol
Brandon |
05-31-2003, 02:28 PM | #11 |
See the primered Camaro up there? Yea, that's what its in.
Brandon |
06-01-2003, 12:54 AM | #12 |
its all about the +6 inches
Somethign else to look at, I am thinking that some of the older 283 engines had an odd style valve cover bolt pattern. You may NEED those covers.
Just something else to look out for on that. |
06-01-2003, 02:55 AM | #13 |
are those corvette valve covers or chevrolet...
70 longbed 496/th400/Ford 9" |
06-01-2003, 10:59 AM | #14 |
They make a bracket for this setup I ran a 327 in my 70 with a short water pump no problems.Even ran it with headers u can get the setup at your local parts store.The most sought after camel hump's are the 461X.You might as well as get the #off the heads and let us know we could guesss all day long on what they are try to get the # off the block allso it is behind the drvs. side head.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
06-01-2003, 11:30 AM | #15 |
what would Neal do?
those valve covers are friggen beautiful.
1968 GMC 910 Long Step 250/3onTree 1969 Chevy C10 longfleet, 350/350 |
06-01-2003, 12:41 PM | #16 |
Looks like the alt bracket is connected to the manifold on the driver side. Just use the old hardware and you should be fine. Also get the numbers off your existing heads. Some of the 305 heads are good for dirt track guys. I sold a set on ebay to a guy who wanted them for his race car. Might be able to make some money on this deal too. Can't ask for better than that.
06-01-2003, 01:20 PM | #17 |
The truck I just got has a 283 in it with the bracket on the exhaust manifold
Where should I look for the head #'s? The heads themselves have no holes in the front of them. |
06-01-2003, 01:24 PM | #18 |
The numbers are under the valve covers. They will be like 6-8 digits long.
06-01-2003, 02:29 PM | #19 |
Hehe I got lucky, the numbers were visible through the oil filler
3884520 and a seperate question, on the block the casting is 3849852, I can find the info for that but on the stamping on the passenger side in front of the head the number is 77 6527382 All I can find is that number should start with a T and it don't help! Last edited by Gee_Emm; 06-01-2003 at 02:41 PM. |
06-01-2003, 02:54 PM | #20 |
Thanks guys. When I go down next week to pick up my truck, I'll pull everything that goes along with them and let ya know. Thanks.
Brandon |
06-01-2003, 03:10 PM | #21 |
Info about heads: 3884520 60.5cc 1.72 1.5 1960-67 Some marked "Made in Canada" also used by studebaker 283/327
Should be ok heads. Good compression for a 283. Not high performance, but not bad either. As for the front stamping, I can't really help you on that. It gives the year and type of vehicle it was originally on. If it is the original engine, then it should point to your truck. |
06-01-2003, 03:16 PM | #22 |
You should decide what kind of motor you want in your truck, then depending on what kind of compression you want, choose the heads that correspond. You should base your decision on port size (64cc or 72cc). Intake and exhaust runners can always be ported and/or polished according to your needs. As far as motors go, I would personally go with the 327. Nothing says loving like a High revvin chevy!
06-01-2003, 03:20 PM | #23 |
ditch the 305. Use it for a boat anchor.
06-01-2003, 03:49 PM | #24 |
hehe I got a 3.0 Mercruiser you can have as a boat anchor too!! Just had to get a new engine for my boat. Got a big crack in the side for easier sinking. I'll even let you have it. That's right, free!! Just come and get it. It's even banded to a pallet already.
06-01-2003, 03:51 PM | #25 |
Here's pic of the POS too. It's a good deal man, take it!
