Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-10-2017, 11:18 PM   #1
Kustomkampe
Signals on dash stay solid
Signal on dash stay solid when I push on break pedal.i also don’t have turn signals.
When I was putting an led bulb in my heater ac controls I saw a spark of some sort but found no blown fuse. Where do I go from here to solve my signal problem?
Kustomkampe is offline   Reply With Quote
Old 10-11-2017, 01:20 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Signals on dash stay solid
A good place to start would be to tell us more about your truck, like what year it is and what else you've done to it as far as the wiring. What kind of dash you have, a three gauge or a seven gauge style. Where else you've put LED lights, and anything else you've modified.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-11-2017, 02:34 PM   #3
Kustomkampe
Thanks V V my truck is a 71 C-10 w/ 350. I’ve put LED’s in all the dash and exterior signals. The dash has a Speedo, temp, oil pressure and fuel gauge. Thanks for your reply’s
Old 10-11-2017, 03:49 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Try reading this thread. I covered the turn signals pretty well with wiring diagrams. It might provide you with some answers. You are aware that ledS require a different flasher than the regular bulbs. You shouldn't see any lights in the dash when you brake unless you have some bad grounds.
http://67-72chevytrucks.com/vboard/s...s+don%27t+work
VetteVet
Old 10-21-2017, 12:36 AM   #5
Kustomkampe
Got the signal problem solved! It was the LED bulbs I but in the signals. They use a different flasher. A friend figured it out quick when he plugged in the new signal switch and it didn’t fix the issue. He put regular 1195’s or 1197’s in it and now I have signals again.
