Old 01-13-2018, 01:05 AM   #1
toddabrown
66 Brake line locations
I have a 66 LWB. Rear still has factory drums brakes although I have switched to 5 lug and replaced with all new parts. Front is an 85 cross member with all new power disk brakes. It has been too long since I removed all the 66 brake lines and what remained of the 85 brake lines. Does anyone have a diagram of where these lines ran originally? 66 or 85? Any help is greatly appreciated.
toddabrown is offline   Reply With Quote
Old 01-13-2018, 10:10 PM   #2
PGSigns
PGSigns's Avatar
Re: 66 Brake line locations
On the setup you have now you will have two lines from the proportioning valve one to the front and one to the rear. The rear will run under the engine on the rear of the cross member and tot he back along the frame rail. Then to the stock bracket for the rubber hose and to the housing. I ran mine for the front down to a tee on the frame rail and a short line to the rubber line to the left front wheel I used existing holes in the frame to bring the front hoses off the upper arm like it was done on the older frame. I then ran a line the line to the other side along the front cross member like the 73 to 87's were done and to the right front hose.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-14-2018, 02:33 PM   #3
Afirehawk1
Same here.
I purchased a set of In-line disc/disc brakes lines with no instructions.
I am only guessing how this goes.
Photos would be great!
Afirehawk1 is offline   Reply With Quote
Old 01-14-2018, 06:28 PM   #4
PGSigns
PGSigns's Avatar
There are lots of treads with pics. Here are a couple. First one is with 72 brake line routing.http://67-72chevytrucks.com/vboard/s...318544&page=12 And one with 73 and up style front hoses.http://67-72chevytrucks.com/vboard/s...318544&page=12
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
