Old 05-29-2011, 10:16 PM   #1
Daddy Brim
Daddy Brim's Avatar
How Do I Reset the Proportioning Valve ?
I guess I lost my rear brakes a short while ago, as the result from a bad wheel cylinder. I knew that I needed new shoes, wheel at some point I broke a front brake line and the master cylinder went dry . NO BRAKES !!! not fun. OK I replaced all of the brake lines the bad wheel cylinder and the shoes. I benched bleed the master cylinder first next I bleed the front brakes and now I'm not getting any fluid out the back. A friend of mine told me I need to reset the check valve inside the proportioning valve. I can not figure this out, I need some help.
Daddy Brim is offline   Reply With Quote
Old 05-29-2011, 10:36 PM   #2
Daddy Brim
Daddy Brim's Avatar
Re: Resetting Proportioning Valve
I should of added this is on a 67 C-20.
Old 05-30-2011, 05:53 AM   #3
Daddy Brim
Daddy Brim's Avatar
ttt
Old 05-30-2011, 07:09 AM   #4
LONGHAIR
It's basically a pressure balancing switch, so you need to relieve the pressure on the side that has more.
Open a bleeder on the higher pressured side and push te pedal down until it gets to the floor, it may "click" at that point. It's not always that easy,but it can happen.
If not, close that bleader and "slam" the brake pedal. It's mostly about "speed", hit it quickly,but forcefully. You will not "feel" it with this method though, you will have to check.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-30-2011, 08:27 AM   #5
cdowns
cdowns's Avatar
if you have the original drum brakes you do not have a proportoioning valve but a distribution block
Old 05-30-2011, 09:12 AM   #6
68gmsee
Active Member
68gmsee's Avatar
^ Correct.
Did you also replace the rear brake line hose?
If you have the drums and you're not getting fluid to the back brakes then either the part of the master cylinder that controls the rear is defective or you have a blockage to the rear brakes.
I'd start by loosening the connectors starting at the master cylinder while having someone apply the brakes to see if you have fluid there and work backwards. And if you replaced the master cylinder, new ones are not what they used to be.
68gmsee is offline   Reply With Quote
Old 05-30-2011, 11:00 AM   #7
Daddy Brim
Daddy Brim's Avatar
So to reset a distribution block is it the same as a proportioning valve ?
Old 05-30-2011, 11:13 AM   #8
OhOneWS6
OhOneWS6's Avatar
There is nothing to reset on a distribution block. Be sure to check the rubber lines. They will swell with age and eventually block off the flow of fluid.
OhOneWS6 is offline   Reply With Quote
