08-24-2018, 03:54 PM | #1 |
Turbo 400 kickdown and LS Motor
I have a new rebuilt turbo 400 with a good street/strip stall installed that I have bolted up to a completely rebuilt 5.3 LS and I am trying to figure out a way to get the kick down to work for the Turbo 400 on the LS. Anyone done this? Any suggestions? Thanks,
08-24-2018, 04:21 PM | #2 |
Re: Turbo 400 kickdown and LS Motor
factory 73-87 trucks had the kickdown switch on the gas pedal under the dash .
we would need a LOT more info on your specific combo of engine / dbc or dbw throttle / vehicle its going in to provide any more help .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
08-24-2018, 05:01 PM | #3 |
72's had the switch on the pedal too, but like the other post said, we need to know what you're putting this in. I just took a pedal with switch out of my truck to replace it with a DBW pedal so I have one for sale if you're building a '72.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
08-26-2018, 10:28 AM | #4 |
Holler at a dude on here called "Willie Make It" he's over in Alabama. He fabbed up a TB for an older style trans. I bought it from him a while back along with a Lokar cable to use with my 4.8/th350. Fit like a glove.
08-27-2018, 01:30 AM | #5 |
400 turbos dont use a kick down cable, they're electrically operated.
08-27-2018, 03:12 PM | #6 |
My bad. I thought all those older style trans were mechanical.
08-27-2018, 03:31 PM | #7 |
Thanks to all of you who responded.
Ok, here is my entire setup: 1969 C-10 - Complete rebuilt 5.3 with Kit from WS6Store with Hot Cam, 92MM Cable throttle body, Headers and such, PSI full Wiring kit and brain, - Stock turbo 400 that came with the truck that was completely rebuilt - 12-Bolt rear end with new Eaton Posi and 3:42 gears - still have the 2 piece Drive line - The pedal in the cab is a Lokar universal pedal |
