Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 01-17-2012, 07:08 PM   #26
01chevduramax
01chevduramax's Avatar
Re: How To Fix Uneven Panel Gaps
I also wanted to show the before just for reference. Not sure why the driver's side was in so much better condition. It only needed a cab corner. This side was TOAST!
'71 org/wht 3/4 ton 4x4
01chevduramax is offline   Reply With Quote
Old 01-21-2012, 01:20 PM   #27
primrrd
primrrd's Avatar
Astronaut
you, sir, are a craftsman!
Duramax,
Your method should be ok, as far as not cracking out. Just know that the edge will be suseptible to chipping out should any thing hit the edge of the cab there hard, or get closed into the door.
Nice thread.
primrrd is offline   Reply With Quote
Old 01-21-2012, 01:58 PM   #28
Sneaux
Sneaux's Avatar
That is a great idea with the welding rod! I am going to have to try that. Thanks for posting the pics.
Sneaux is offline   Reply With Quote
Old 01-23-2012, 03:21 AM   #29
01chevduramax
So is everyone else in agreement with 1/4" of filler in a door jamb being OK? Thanks for your reply primrrd!
Old 01-24-2012, 06:35 PM   #30
theastronaut
theastronaut's Avatar
As primrrd said, it will stick/adhere ok but if anything bumps the edge you'll have a large chip. Is the truck something you're gunna keep for awhile? If so you may want to try a more permanent repair. Filler has it's place when doing bodywork and is great stuff when used properly but it has it's limits too. It will probably be pretty durable as far as not cracking since it's on a stiff edge that shouldn't flex much but it will be very suceptable to chipping since it's on an edge.
theastronaut is offline   Reply With Quote
Old 01-27-2012, 09:51 PM   #31
01chevduramax
I am planning on passing this truck down to my boys when that time comes. So a more permanent fix is definately what I'm looking for. I guess its better to find out now before its all painted.
Old 02-01-2012, 01:16 PM   #32
trout
wow this is kool idea here
Edited by staff
trout is offline   Reply With Quote
Old 02-03-2012, 02:59 AM   #33
68 TT
Still plays with trucks
68 TT's Avatar
I had one like that too. The way it was parked in the PO's driveway put that side facing the front of their house and it got watered all the time by the sprinkler system.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-12-2012, 11:43 AM   #34
kev2809
low n' slo
kev2809's Avatar
i have a question...can you take a picture of the back side so i can see what it looks like after welded up?
i started welding my door up last night and was wondering what you guys are doing on the back side after its all welded up..
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 02-14-2012, 10:35 PM   #35
flips72
flips72's Avatar
thanks for the info, i just did my driver door and it turned out ok for a rookie, thanks again theastronaut.
flips72 is offline   Reply With Quote
Old 02-15-2012, 10:42 AM   #36
theastronaut
I didn't take any pics of the backside when I was taking pics for this write-up, but I don't fully weld up the backside to minimize the amount of heat from welding. The gap on the back looks just like the front does before welding the rod to the door edge. I do like to weld the backside gap every few inches. The gap gets ground out with a 2" sander with a 50 grit disc to roughen up the surface so filler will have a better surface to stick to. The edge is already three layers thick and now has a 1/8 rod welded on, so the edge doesn't flex enough for the filler to crack.
Old 02-15-2012, 10:43 AM   #37
theastronaut
Looks great!! You'll be amazed at how much neater the finished body and paint work looks with even gaps! Nice job on the BBW conversion too!
Old 02-16-2012, 07:33 PM   #38
flips72
flips72's Avatar
thanks for the kind words, and i appreciate the thread, this should be a sticky.
Old 02-17-2012, 11:01 AM   #39
HuggerCST
HuggerCST's Avatar
You're right, thanks for the heads up. I added it to the body FAQ thread.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 02-17-2012, 12:56 PM   #40
theastronaut
Oh wow, thanks! Glad to be able to give back to the forum, you guys have helped me a ton since I joined!
