09-23-2009, 05:51 PM | #1 |
edelbrock inline 6 manifold?
I saw an edelbrock aluminum intake for an inline 6 cylinder. how do I find out more info? anyone know the model number of this intake?
1967 K20 Stepside Longbed 250-6 sm420 |
09-23-2009, 06:36 PM | #2 |
283 Drama Queen
Re: edelbrock inline 6 manifold?
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
09-23-2009, 10:56 PM | #3 |
You are looking for Edelbrock SP2P intake. I had one,I sold it,so I could buy a Offy 4 barrel intake.
The intake was designed to use a single,one barrel carb. Jimmy |
09-24-2009, 05:50 AM | #4 |
I may be wrong, but I'd guess it fits the older 235, 261 L6s, not the "late" 230, 250, 292s that started with the '63 model year.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 09-25-2009 at 06:21 AM. |
09-24-2009, 10:16 AM | #5 |
Active Member
I don't believe Edelbrock makes them anymore but they may make them for other companies. I did a search some years ago and the only two that I was able to come up with was the Offenhuser (Landon Stovebolt) and the one sold by Clifford Performance.
09-24-2009, 05:08 PM | #6 |
so it only accepts a one barrel carb, nothing else?
09-24-2009, 07:44 PM | #7 |
The intake was designed as a direct replacement for the stock intake.
The edelbrock intake used a Single, one barrel carb. The intake was desiged to be used on 194,230,250 292 engines. The edelbrock intake was not designed to be a performance intake. It was designed for better fuel mileage. Jimmy |
09-26-2009, 05:26 AM | #8 |
OK. I'm always happy to learn something new.
02-12-2011, 03:16 PM | #9 |
i have one on a 1957 235 in my 1951 Chevy Fleetline. it has two Rochester one-barrels that run at the same time. it's finned and aluminum. i bought it in the 80's and have never seen another one. i'll try to upload a picture.
1981 Chevy C30 440 Holmes 42K one owner miles |
02-13-2011, 08:24 AM | #10 |
Watch out for your cornhole !
What Jimmy is talking about is true. The SP2P series of intakes were not high performance by any means. I actually got into collecting SP2P intakes a few years ago for some reason.
During the 70s, and the gas crunch, Edelbrock decided to market a full line of intakes aimed strictly at gas mileage improvements. Folks were trading their American cars in on Toyota and Datsuns because of the oil shortage. Edelbrock hoped to capitalize on this by offering increased economy. The SP2Ps were available for a lot of different engines, including the 194-292 series of inline 6 GM engines. I've also had them for SBC, BBC, small block Ford, and AMC engines. They really aren't worth anything so I just hang them up for shop wall bling. It's a neat little piece of history.
02-13-2011, 05:01 PM | #11 |
Decided to just keep the Orig. 235 in my 61'. Consider going with an intake to put two single barrel carbs on it. What are the Pros and Cons of going with this set up? My dad says I'd blow the motor with two carbs on....What do y'all think?
02-13-2011, 06:30 PM | #12 |
I built it
ive never heard of a engine blowing up from multiple carbs.. especially a straight 6, they're pretty much indestructible
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
10-13-2011, 11:34 AM | #13 |
Have one similar to this, can you tell me why they are water heated?
Chevy Iron Fully customized 1968 C-10 Stovebolt 292, T-5 trans 3:73 posi Wife says it's a "midlife crisis".....I'm okay with that. |
10-13-2011, 12:21 PM | #14 |
Because the intake manifold hangs off the side of the engine and doesn't get much heat from it. The intake manifold runners need to be somewhat warm to keep the fuel atomized well for decent drivability. Hence the lines to use warm coolant into the manifold.
The original manifolds didn't need this since they were married to the exhaust manifold and the heat conducted up into the intake this way. Your aftermarket aluminum manifold won't have that option.
10-13-2011, 12:48 PM | #15 |
Just a car guy
I had a clifford on my 6 before I ditched it for the 350.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
10-13-2011, 03:00 PM | #16 |
i have had dual carbs on my 235 for literally 35 years. it runs great. it wont blow up.....
10-13-2011, 04:01 PM | #17 | |
Active Member
http://stoveboltengineco.com/index.p...take-manifold/ |
10-17-2011, 01:20 AM | #18 |
I won't argue that carb heat isn't a good idea with some sound theory behind it, but I've been running a 4 barrel on an Offy intake w/o carb heat on 292s for 33 years. I will admit that the truck runs better in the summer. I live in Tucson where 100*+ temperatures are normal in summer.
10-17-2011, 06:10 AM | #19 |
No heat in MI = fuel drop out, poor driveability and fuel economy. Particularly with any alcohol in the gas, it's rather settle out as a liquid then stay in the air column.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
10-19-2011, 05:14 PM | #20 |
Inline 6 Manifold Heat
Went to the Link sent by 68gmsee and just as explained; my aftermarket has had a tube (nicely) welded to the bottom but then coolant lines aborted. It appears I may have found the answer to my 292's sluggishness. I will reroute the coolant lines to run through the tube and see how it goes.
10-19-2011, 06:47 PM | #21 |
Sounds like your dad shouldn't be dispensing any automotive advice.
