Old 03-24-2015, 11:56 AM   #26
creep
Registered Loser
creep's Avatar
Re: Power steering with GMC V6?
My question is, why hasn't Captainfab started making these?
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 03-24-2015, 12:10 PM   #27
creep
Registered Loser
creep's Avatar
This is the PS pump bracket I bought off ebay. I have no idea if it's correct or not because I changed my motor plans when I found out the motor wouldn't fit back in (easily) after I bagged my truck.
Old 03-24-2015, 11:33 PM   #28
Captainfab
60-66 Nut
Two reasons. One is finding pulleys that will work and second, I simply don't have the time with working 70-80 hrs a week every week.
Old 03-25-2015, 10:52 AM   #29
jbgroby
jbgroby's Avatar
The old Webshots link dies, so I had to shift EVERYTHNG over to photobuckets - Oh Joy!
Here are the pictures of my OEM mount setup, not the tie into the engine mount bolts.
jbgroby is offline   Reply With Quote
Old 03-25-2015, 11:59 AM   #30
GTS61
Awesome pictures especially for someone new like me. I love the paint job also. Maybe someday I will paint my engine. Thanks a lot for posting these:-)
Greg
GTS61 is offline   Reply With Quote
Old 02-17-2017, 11:19 PM   #31
1774btcrew
1774btcrew's Avatar
I know this is a really old post but I don't know anything about the GMC v6s other than the PS brackets are relatively hard to come by. I have found a big truck with the brackets(a/c) as well. I have heard the big truck brackets are somewhat different. Does this mean they will not work on the smaller trucks? I appreciate any advice
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 02-18-2017, 07:21 AM   #32
GTS61
[QUOTE=1774btcrew;7862195]I know this is a really old post but I don't know anything about the GMC v6s other than the PS brackets are relatively hard to come by. I have found a big truck with the brackets(a/c) as well. I have heard the big truck brackets are somewhat different. Does this mean they will not work on the smaller trucks? I appreciate any advice[/QUOTE
Big truck brackets? What truck do you mean? Canyoutake a picture of it?
Old 02-18-2017, 01:29 PM   #33
padresag
if you have found the truck, have a look at the bracket and compare it to the one Jake has shown above. the engine blocks are all the same. biggest difference will be in the pulleys
ron
padresag is offline   Reply With Quote
Old 02-18-2017, 01:49 PM   #34
MusicMan70
MusicMan70's Avatar
Here is a big truck V6 with power steering. I've seen them mounted high up as well as off to the side, like this one. I don't feel it would fit a light duty pick up.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 06-04-2019, 12:41 PM   #35
AngryPirate
AngryPirate's Avatar
Does anyone know if someone is actually making these brackets yet and if the double pulleys for the fan are more accessible or someone has found an alternative source part that would do the job?
I would like to get power steering, but I would also like to steal the hydraulic pressure for a brake booster set up as well (hydraboost).
Thanks!
AngryPirate is offline   Reply With Quote
Old 06-04-2019, 02:13 PM   #36
MusicMan70
MusicMan70's Avatar
AP; check out Rockdrillers build here;
http://67-72chevytrucks.com/vboard/s...=453161&page=4
He’s using a hydro boost on the V6 and made his own PS pump set up.
Far as I’m aware no one is making any brackets.
MusicMan70
1961 GMC Suburban
Old 06-05-2019, 10:22 AM   #37
AngryPirate
Thanks MusicMan! I'll have a look.
Old 10-22-2019, 08:24 PM   #38
sstock
sstock's Avatar
He is a picture of my low miler 64 GMC 1/2 ton.
Seems my pump is a different design to what I am used to seeing. Also, does anyone know of rebuilt kits to service the power cylinder and control valve, these are leaky little devils?
Steve
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange
1964 GMC 1000 series,custom, 305E, sm420
sstock is offline   Reply With Quote
Old 10-22-2019, 11:38 PM   #39
Captainfab
60-66 Nut
The cylinder and valve are basically the same as was used in the Corvette's up until '81?
Old 11-20-2019, 11:43 AM   #40
sstock
sstock's Avatar
Thanks Captain, but finding it hard to get the right pump seal kit. I'm thinking it is a saginaw unit but did GMC's use a medium duty truck pump? This is not what you typically see on 1/2 ton trucks.
Steve
Old 11-20-2019, 12:16 PM   #41
60-66
60-66's Avatar
Steve
All the power steering seal kits are showing for GMCs with V6s on the Rockauto site
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 11-20-2019, 09:16 PM   #42
sstock
sstock's Avatar
I see that and am skeptical if they are indeed for the medium duty pumps, I ordered a couple kits and will see if they are right or not, will report back but have a hunch they will fit the other smaller saginaw pumps that are more prevalent in chevy vehicles.
Old 11-21-2019, 01:50 PM   #43
BobS
BobS's Avatar
IIRC, Oldsmobile and maybe others also used that pump in the mid-60's. I had researched the part numbers at one point and found the Olds models it was used on but have no idea where that is now. I can get you the original GM part number for the pump if that will help.
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 11-21-2019, 08:31 PM   #44
sstock
sstock's Avatar
Bob
That would be great Bob, because I just received the rebuild kits from rock auto and they are both for the smaller saginaw pumps. So to recap, guys wanting power steering seal kits for the pumps for GMC Rock auto has sourced the wrong seal kits from all the vendors they are for the small pumps not for the GMC medium duty pumps found on at least 1/2 ton GMCs with 305 V6 engines. I have my brackets off , glass beaded and painted so if someone wants pictures and measurements, now is the time.
Steve
Old 11-22-2019, 11:47 AM   #45
BobS
BobS's Avatar
As of the 1964 GMC parts book (printed in Sep 63), the part number for that pump was 5686708. That might get you pointed in the right direction with someone who isn't afraid to break open a book instead of just punching numbers into the computer. A quick search on the internet shows it was also used on both Olds and Pontiacs so restorers of those makes might be a source of information also. So far, the only thing not leaking on mine is the pump, I suppose that day is coming.
Bob
66 GMC 1000-V6
66 GMC 1500-V6
68 GMC C1500-V6
68 GMC C1500-V6
70 Chevy K20-SBC
72 Chevy C10-SBC
Old 11-22-2019, 10:31 PM   #46
sstock
sstock's Avatar
Thank You Sir
Old 11-23-2019, 11:54 AM   #47
BobS
BobS's Avatar
You're welcome! If I find anything, I'll get it posted and let you know.
Bob
66 GMC 1000-V6
66 GMC 1500-V6
68 GMC C1500-V6
68 GMC C1500-V6
70 Chevy K20-SBC
72 Chevy C10-SBC
Old 01-12-2020, 05:42 PM   #48
AngryPirate
*It's been a while and I do not guarantee that this was the exact way I did it but...I believe I used this bracket from Ebay. I had a friend make an adapter plate to help me mount it to the water pump. The upper bracket bolts to the engine plate. My fabrication skills are rudimentary at best, but I do have power steering now and have driven this unit over 400 miles without incident. It still needs improving.
Some general questions, but MusicMan seems to have some good details in his post.
I have 1960 GMC with a 305A v6 and I am slowly gathering parts for my power steering addition.
I notice that the tricky part is the double groove pulleys for the crank and water pump.
Would anyone know if I would need 305v6 pulleys or if other pulleys work from other engines?
The water pump ones for SBC's look really similar, but searching ebay, everything says SBC for the cranks.
Thanks for any advice or tips.
Also, @MusicMan70, the bracket you modified to install your pump, do you remember what company made it / part # ?
Thanks,
Scott
Old 01-15-2020, 09:20 PM   #49
MusicMan70
MusicMan70's Avatar
AngryPirate; Here is a link to an eBay listing for a similar bracket.
https://www.ebay.com/itm/SBC-Power-S...pe!92881!US!-1
I have not investigated whether SB pulleys would work but my guess is a no.
MusicMan70
1961 GMC Suburban
