10-22-2019, 08:13 AM | #1 |
ls3 swap 4l60e hits floor
ls3 4l60e swap, transmissor hits floor, engine has a 8 Degree rake
stock oil pan, suspension drop. trans dept motor mounts. any way to lower transmission from hitting floor ? Last edited by 67 stable; 10-22-2019 at 08:15 AM. Reason: adding |
10-22-2019, 09:24 AM | #2 |
Re: ls3 swap 4l60e hits floor
Stock LS3 oil pan? Those usually wont work on a truck, so maybe the engine is too high?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
10-22-2019, 11:57 AM | #3 |
Ok 8 degrees in reference to what and that trans should clear the floor. Pictures would be a big help.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
10-22-2019, 01:07 PM | #4 |
Post Whore
(Hitting the floor).....do you mean floorboard of truck?
(8 degs rake)....is your frame level..0 degs.... and your driveline is 8 deg down in the rear ....is this what your sayin? If your already at 8 deg down in the rear that's to much ..should be around 3 deg downward angle...but it needs to match the differential upward angle...what is your diff angle when the truck is sitting on all 4s? You may need to do a trans tunnel or lower engine Like said some pics will help as well as what your putting it in..
10-22-2019, 02:16 PM | #5 |
Which perch/motor mount/ adapter setup you using? What’s this going in?
10-22-2019, 11:10 PM | #6 |
60-66 Nut
Knowing the year of truck would help with giving possible solutions.
10-22-2019, 11:57 PM | #7 |
its a 67 c-10
10-23-2019, 01:34 AM | #8 |
I’ve got a 68 I LS swapped an LS3 and 4L80, running CPP engine mounts, DD sliders and stock trans mount I think I was roughly 4.5* down slope. 8 sounds high.
10-23-2019, 08:49 AM | #9 |
can anyone recommend a oil pan swap ?
Okay i think i might have figured out the clearance problem. we used the rear ( six cylinder) engine mount holes, because of the oil pan clearance. we can movie the engine forward, that might level it out, but i don't see how it will lower the tranny. how do you upload pics ? |
10-23-2019, 01:42 PM | #10 |
Post Whore
10-23-2019, 01:43 PM | #11 |
Post Whore
12-09-2019, 10:53 PM | #12 | |
using the trans depot engine mount and stock frame mount anyway to lower the engine with different mounts ? |
12-09-2019, 11:22 PM | #13 |
I used the stock v8 perches in the v8 position with 1 inch set back plates and it doesn’t hit floor. Truck oil pan. I have a couple inches of clearance between tunnel and transmission. Angle is close but I have space to dial it in.
With a 1 inch setback the engine is in the same spot as a 350. I will be using another set of adapter plates so I can do a 2 inch setback to be able to use the original driveshaft. As it is, the yoke is not as far in as I’d like. Posted via Mobile Device |
12-09-2019, 11:25 PM | #14 |
This is in a 1971 c10 with a low hump.
12-10-2019, 10:31 AM | #15 |
Looks like these mounts make your engine sit too high. Same thing happened to me with the square body c20 mounts.
