Old 09-02-2002, 02:20 PM   #1
HELLCAT
Driveshafts and Lift
I have a 72 Jimmy been doing a frame off job on for some time now...anyway I`m to the point where I need to decide on a 2" or 4" suspension lift, I have 2" of body lift in it already. Could someone tell me if I `ll need to get my driveshafts lengthened with a 4" lift, and how bad will it be on u-joints since the Blazer rear shafts are so short and at a steep angle to begin with. Thank You
`72 Jimmy 6" n 35`s
`68 Chevy II SS 396
`98 Dodge Ram
`01 Audi TT
HELLCAT is offline   Reply With Quote
Old 09-02-2002, 06:47 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
4" should be no problem. I had an 85 w/ 4" lift and it's driveshaft is shorter then what you have because of the NP208 transfer case's tailshaft.
Welcome to the board!
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 09-03-2002, 09:26 AM   #3
Beast388
Suburbans RULE!
Beast388's Avatar
When I put a 4" lift in my Suburban I had to have the rear shaft lengthened. When I went to install the rear shaft after the lift I pulled the splines all the way out and I was about 1/2" from seating in the yoke. Obviously too short. The front shaft was fine.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 09-03-2002, 09:51 AM   #4
Mike C
Mike C's Avatar
I have 4" on my Jimmy and had no troubles with the stock rear shaft. I first had 1 1/2" add-a-leaves and 2 1/2" blocks but bent the axle housing perches! It now has a set of 4" National springs in the rear but I disposed of the EXTREMELY clapped out stock rear shaft for a Tom Woods CV joint rear shaft. The rear springs tilt the rear axle up to a virtually zero pinion angle which is correct for a CV shaft, but not for a non CV shaft. I had tossed my original shaft out a couple of times after breaking rear yokes and/or u-joints and it was tweaked as well as just worn from 300k+ miles. The new shaft elimintated about 2/3 of the slack in the driveline.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-03-2002, 05:24 PM   #5
HELLCAT
Thanks for all your input guys! Sounds like I`ll get by with my stock shaft lenghts and 4" of lift... in a old Jimmy anyway. Now I just have to decide, 33`s with 4" total lift or 35`s with 6" total. Decisions decisions!
`72 Jimmy 6" n 35`s
`68 Chevy II SS 396
`98 Dodge Ram
`01 Audi TT
Old 09-03-2002, 10:33 PM   #6
Mike C
Mike C's Avatar
35's of course. My truck looked supid with 33's I thought. 4.10s and the 33s was too much, but perfect for the 35s.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 09-04-2002, 05:14 PM   #7
Yukon Jack
Yukon Jack's Avatar
When I did my initial 4" lift on my '69 I did have to have the front driveshaft lengthened and even had to add a CV joint. But mine has the Rockwell T221 transfer case. From what I have gathered, usually a 4" lift on the years after they stopped using the Rockewell (after 69), don't need to have the shaft lengthened.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-04-2002, 08:08 PM   #8
Mike C
Mike C's Avatar
The NP205 trucks should come with a CV shaft in the front. At least the 3 I have had did.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 09-07-2002, 12:40 AM   #9
DaHateTank
Yep.
Don't worry about U-Joint life too much, either. When I first lifted my heap, I was going thru U joints quite often. Then I discovered that my yoke was thrashed. After fixing that, the joints last for a couple years, or so.
Although thats a pretty short lifespan, when compared to a stock truck, they're cheap, and easy to replace...so, IMO, its no big deal. Well worth it, for the increrased clearance, traction, etc.
My beater has a 6" Lift in it, BTW.
-M
DaHateTank is offline   Reply With Quote
Old 09-28-2002, 02:41 AM   #10
Fast68Chevy
Fast68Chevy's Avatar
Mike, when you say zero pinion angle you mean perfectly horizotal right ?
that would explain why some trucks have perfectyl horizontal pinion and why some are tilted up/back a bit,....
hmmmmm.........
Fast68Chevy is offline   Reply With Quote
