Old 07-11-2017, 11:54 AM   #626
99 to Life
99 to Life's Avatar
Re: S10 Swap how to
I couldn't see any issues with 1" longer column.
51' 3100 s-10 frame lowered,bias whitewalls, 355,5speed, patina, done, baggin it now!
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49' 3100 s-10 frame bagged, vortec, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, 53' COE
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 07-14-2017, 10:03 PM   #627
joedoh
joedoh's Avatar
Re: S10 Swap how to
On the first couple of pages it is suggested to use a 32" column, would a 33" column be too much? Or can I get away with that?
I've found one I like, but it's the extra inch.
just make sure you fit behind the wheel before you make it permanent. these trucks dont have a lot of room with the stock seat and still are tight (to the steering wheel) with a late model truck seat.
Project: Hannah
my 4.3 5spd S10 41 Chevy 1/2 ton
http://67-72chevytrucks.com/vboard/s....php?p=8029533
Old 08-15-2017, 03:32 AM   #628
dettmer13
Re: S10 Swap how to
I have my 51 cab and body mounted on my 92 S10 frame. I placed the cab mounts 2 1/8" forward of the oval holes. All the bolt holes in the cab line up with the mounts well. I hung my fenders, core support, inner fenders, and hood support. I cut the front frame horns 1/2" off of the steering box as well. When I tried to mount my grille to mock it up, the vertical supports that hold the grille together are hitting the frame rails. Did anyone else have this issue?
dettmer13 is offline   Reply With Quote
Old 08-15-2017, 10:21 AM   #629
skymangs
skymangs's Avatar
Re: S10 Swap how to
notch the framerails for grill uprights. i've run into that before. remember, no two of these is exactly the same. that's exactly why no kit will ever fit as good as a custom build!
skymangs is offline   Reply With Quote
Old 08-15-2017, 11:32 AM   #630
joedoh
joedoh's Avatar
Re: S10 Swap how to
I actually like to cut the framerails back to just before the first bolt hole of the steering box. the steering box actually sticks out past the framerail this way. and not to make it more complicated, but I cut it at an angle or leave the lower part of the framerail longer so I have plenty of room for bumper brackets.
would that give you room for your grille uprights?
Project: Hannah
Old 08-15-2017, 03:20 PM   #631
tlorber
tlorber's Avatar
Re: S10 Swap how to
Shock absorber question-Does anyone here have input/preference for S10 shocks? I've got 2" drop spindles in front and 3" lowering blocks in the rear, so as I understand it I preserve the original dimensions for shock length. I'd like to at least consider air adjustables for the rears in case I carry a heavy load, but handling is more of a priority.
Thanks for any input.
tlorber is offline   Reply With Quote
Old 08-15-2017, 08:38 PM   #632
dettmer13
Re: S10 Swap how to
Thanks guys, I'm sure it will give me plenty of room. It's only hitting by about an inch and a half. I'll take a better look at it on my next few days off. Working nights really puts a damper on projects.
Old 08-15-2017, 10:19 PM   #633
Michael_G
Re: S10 Swap how to
Skymangs, do I need to clearance my frame rail on the driver side for my exhaust to clear? I know nobody has mentioned this as I've read this post over multiple times over a year now. I have a 54 that I've used your cabstand design on a 94 LBRC chassis and I've installed an 04 6.0 LS with about 1" behind the passenger head to firewall for clearance and on the driver side the stock rear manifold looks like it's shooting straight for the frame. Am I missing something or will it clear?
Michael_G is offline   Reply With Quote
Old 08-15-2017, 10:31 PM   #634
OutlawDrifter
Re: S10 Swap how to
Check my build in the projects section "Francis the Tow Pig". I moved my engine 1.5" to the passenger side and still had to cut the manifold and change the direction. They are made out of cast steel so you can weld mild steel pipe on them.
2010 Chevy 2500HD Z71 CCSB, 6.0L/6L90E, 3.73, G80
1991 Z/28, 6.0L/T56...I think it has a cam.....
Replaced:
1979 Bonanza K10 RCLB 350/350/NP203 3.42's
1982 K5 Sierra Classic 2WD, 350/350, 2.73's
1995 GMC RCSB 2WD, 5.7tbi/4L60E, 3.42's
1998 Chevy K1500 Z71, 5.7L/4L60E, 3.43's
Old 08-15-2017, 10:42 PM   #635
Michael_G
Re: S10 Swap how to
Will do. Thanks. I'm doing a 6. 0/4l80e combo. Been sitting idle on it for other builds and I'm going to jump on it and have it on the road hopefully by January.
Old 08-16-2017, 09:29 AM   #636
Speedysdad
Re: S10 Swap how to
I am building my first truck using this website as direction. I don't want to use the in take fuel pump. I can't use a mechanical, so I need something like the rotary vane. Reading the reviews for fuel pumps on Summit/Jegs/Speedway they all are loud and unreliable. I need opinions from those that have a success story
Jim
Building my first hot rod
54 Chevy truck, S10 frame
383/700r4/373
Speedysdad is offline   Reply With Quote
Old 08-16-2017, 10:08 AM   #637
99 to Life
99 to Life's Avatar
Re: S10 Swap how to
I used a carter rotary vane from summit, had it running and I doubt you'd ever hear it even at idle. Yet to have the truck back together to verify all that. The nice thing about the rotary vane is easy to install, cheap and from what I read reliable. It was maybe 50$ or something.
Old 08-16-2017, 10:22 AM   #638
99 to Life
99 to Life's Avatar
Re: S10 Swap how to
SHOCK answer, I was enlightened by joedoh on the Belltech drop shocks. Check them out on summit.
Old 08-16-2017, 12:04 PM   #639
tlorber
tlorber's Avatar
Re: S10 Swap how to
Thanks, 99. I found those yesterday, and I'll probably order up a set today. Tire Rack seems to be the place.
Old 08-17-2017, 12:07 PM   #640
skymangs
skymangs's Avatar
Re: S10 Swap how to
i use stock monroe's up front with drop spindles and i can think of no reason to not use air shocks in the rear.
i don't recommend using stock manifolds for that exact reason. any shorty header will work, or if you can find them, trailblazer SS.
and he's right, i've been running a Carter rotory vane in my son's 48 for 5+ years.
Old 08-19-2017, 12:16 AM   #641
RedFoot
Re: S10 Swap how to
On the 1950/s-10 frame swap. Has anyone done a in frame master cylinder/power booster pedal assembly ? Instead of on the firewall ? Similar to what they used in the early 50s. If so what named brand kit did you use that fit the s-10 frame.. No reason to use in frame , other then trying to cleanup and smooth the firewall.
RedFoot is offline   Reply With Quote
Old 08-19-2017, 02:27 AM   #642
ramzbusa
Re: S10 Swap how to
Had a question guys. My 50 chevy has nothing in the engine bay nor the inside of the cab. I only have the steering column of a 93 s10. It sits on a 94 s10 frame. Do you guys recommend i buy a running vehicle with the engine/trans combo i want and use everything and anything i can from that vehicle? (Seat, driveshaft, trans oil cooler, brake booster...) Or should i just buy the engine/trans pullout and then get the other stuff from a junk yard as i need it? Want to see what route would cause me less headaches. Thanks in advance!
ramzbusa is offline   Reply With Quote
Old 08-19-2017, 11:03 AM   #643
gigamanx
Re: S10 Swap how to
I'd say it depends on what your ultimate goal is for your truck. I just tore down my S10 this year and plan to put a V8 engine in it. What's left of the S10? Suspension, steering box and arms, frame, brakes. That's it. I had to get a wiring harness, I chose to get a steering column because a $180 craigslist one looks way better than the stock S10 in an old truck. Ultimately, I'd say there is very little of the S10 still left. Now, part of that reason is because of the engine change, so I didn't need the wiring harness anymore. I also couldn't fit my existing transmission, so I had to source on of those too.
(I do have a 2.8L v6, wiring harness, and matching transmission if you can find a way to ship it to Texas )
If you're already rolling on an S10 chassis with suspension, steering, and brakes, there isn't much value in tearing apart another one unless the plan is to drive with the V6 engine and trans it comes with. If your dreams are for an LS swap with a 4L60E or similar transmission, then an engine and transmission pull with a new wiring harness makes much more sense, IMO.
I am on truck 1 of 1, there are others who have done a bunch of these builds. I believe I asked the seat question before and the S10 seat doesn't fit the Chevy 3100 cab.
gigamanx is offline   Reply With Quote
Old 08-19-2017, 01:35 PM   #644
skymangs
skymangs's Avatar
Re: S10 Swap how to
i did an under floor master on my 49 (in my sig), but i didn't use a kit, i built my own.
as for the 50, i'd buy a nice 5.3 takeout with a 2wd trans, wire harness, and computer. then sorce everything else. gm g bodies make a good doner.
Old 09-14-2017, 07:35 PM   #645
Nchristi
Re: S10 Swap how to
I'm currently working on my s10 swap. I've got a 53 gmc that I'm putting on an s10 frame. I purchased a zr2 rear end, a chevy 2500, a 98 blazer for parts. My question is will the zr2 rear end work. I've heard some say it will an some say it won't. I was on the ad-engineering website and they said the zr2 will not work. Is this just for their kit? Also I'm wanting to know what wheel and tire sizes for this setup including offset and back spacing for an 18" wheel. I plan on purchasing 2" drop spindles and 3" blocks for the rear. Thanks
Nchristi is offline   Reply With Quote
Old 09-14-2017, 08:01 PM   #646
99 to Life
99 to Life's Avatar
Re: S10 Swap how to
http://67-72chevytrucks.com/vboard/s...448842&page=15
check out daverods build, uses a zr2 rear. I'm about to do the same thing.
Old 09-14-2017, 09:49 PM   #647
Nchristi
Thanks for that link. I think it'll work since I don't plan on using bags in he read. If anyone has the zr2 rear with blocks I'd like to hear what type of wheels / tires you're running with offset / back spacing
Old 09-15-2017, 02:19 PM   #648
tlorber
tlorber's Avatar
Re: S10 Swap how to
Nchristi,
My rear tire size is 255/50/17. I don't remember the wheel offset, but I don't think there is any. My rear axle is from a '70 Chevelle, which is around 61.5" from mounting surface to mounting surface. I did not want to tub my bed, which is why I used such a wide axle. My tires just barely clear the bedside (by like 1/4") so I will probably kick them out about 1" or so with spacers. I have to wait until I put the rear fenders back on to determine clearance, but those 255 tires will be a pretty tight fit between the bed and fender.
Old 09-16-2017, 01:16 PM   #649
skymangs
skymangs's Avatar
Re: S10 Swap how to
as far as the manifolds go, I never use the stock manifolds on an LS swap, for that very reason. any cheap blocks hugger will do.
Old 09-18-2017, 02:19 AM   #650
KRFitz
Re: S10 Swap how to
Hi Guys, new to the thread, 1st post. I'm considering doing an S10 swap on my '51 5 window. Is it possible to use the 4.3L as it sits without moving the motor position? Looking for the simplest way to approach this project. Thanks for sharing your knowledge.
KRFitz is offline   Reply With Quote
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
