Old 08-18-2017, 09:10 PM   #1
kwmech
454 ARP and exhaust manifolds
So I'm into the final assy of the rebuilt 454 I'm putting in place of the original 350 in my '69. I used a nice set of ARP head bolts. Going to put the exhaust manifolds on first so I don't have to fight them over the fenders and glad I did. Turns out the manifolds hit the top of the ARPs, thus not letting them fit flat on the cylinder heads. The manifolds are new Dormans so I'm not too fond of grinding on a brand new manifold. As it is now I am sanding (with my air sander and 36 grit) the top and one edge of the bolt head... Yikes. Still plenty of meat on the bolt itself, but.... Anyone else run into this or is it headers for everybody. Not a header fan myself on a daily hauler
Old 08-20-2017, 06:32 AM   #2
truckdude239
truckdude239's Avatar
Re: 454 ARP and exhaust manifolds
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 101kmiles
2002 Honda Accord 4 door With 275k(sisters car)
2003 Honda Accord 109k( brothers car)
2002 Sububran 5.3 225k
2000 Tahoe 5.3l 369k
Old 08-21-2017, 07:56 AM   #3
Tiger Joe
Yes we had the issue on our 468 build, and my dads neighbor had issues with his big block.
both of us using headers but different applications. I don't know what brand he used. our were hooker for a 79 c30
it would probably take you a long time to sand down ARP bolts, as they are pretty hard steel.
we ended up just putting stock head bolts back in the bottom row. my dads neighbot ended up having his ARP bolts machined down to fit.
Tiger Joe is offline   Reply With Quote
Old 08-22-2017, 06:40 PM   #4
kwmech
They actually sanded down pretty quick with 36 grit and my air sander. Couple of pics for ya
Old 08-22-2017, 09:24 PM   #5
70K10Hunter
70K10Hunter's Avatar
Do you absolutely need the washers? might give you a little room and not have to shave so much of the bolt. just a thought...
70K10Hunter is offline   Reply With Quote
Old 08-22-2017, 10:30 PM   #6
kwmech
Yeah I thought about just that, but I didn't want to disturb the torque settings. What you see is completed, everything is clearanced and torqued down.
Old 09-02-2017, 01:59 AM   #7
Ironangel
Ironangel's Avatar
What are the silver bolt heads? Are those plugs for an air injection? I like the shields and with all that cast iron mass they're going to be necessary. It looks good and as long as everything is clearanced you should be good to go. Personally, I wouldn't have touched them bolts before giving them manifolds the once over with one of these but thats just me...
Michael Hill, "Ghostrider"
1980 KZ-1000 ST-MKII, "Baby Doll"
72 Chevy C/10 SS-396 w/Comp Cam=268H, Closed Chamber 290 heads, Stage-4 Power Pack (Eagle Red's) 350THM, Beefed up 12-Bolt, Eaton 4:56 Posi, (Diesel Killer) Street Rod LWB "Nasty Sally"
72 Chevy C/10 Rebuilt 350 w/Voodoo-10120701 Cam, Stage-4 350THM, Beefed up 12-Bolt 3:73 Eaton Posi, LWB Wood Bed, (Daily driver, work horse) "Belle"
https://www.facebook.com/michael.hill.12979
https://www.facebook.com/kz1000rider/
Ironangel is offline   Reply With Quote
Old 09-02-2017, 02:26 PM   #8
kwmech
The Dorman manifolds are already pretty thin without grinding on them, that's why I went the other way. And yes the plugs are the air injection holes. All the replacement manifolds are universal, even down to the O2 sensor hole.
Old 09-02-2017, 05:48 PM   #9
mattfranklin
mattfranklin's Avatar
Fascinating. I did a quick google with "454 gm arp head bolt clearance with stock manifolds" in the search term box and saw that a few others had the same issue -- even with headers. Those guys were either grinding the header flange or searching out stock bolt sets without the fat washer.
Good to know if I ever get tired of my small block.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 09-03-2017, 10:31 AM   #10
Marv D
Registered Truck Offender
Marv D's Avatar
You may have had clearance issues anyways with the Dorman imported cast manifolds...., but WHY did you use the washers?? Just because they were in the kit?
Washers are necessary to keep the hard steel bolt from gauling ALUMINUM heads and influencing torque value. . You don't need the washers with iron heads (which these appear to be with that casting texture and casting flash,,, but they 'may be' painted aluminum heads???) Regardless iron and steel will not gaul so just the ARP moly torque lube and no washer would have been perfectly fine here.
Grinding on the bolt before, removing the washers is definitely not the prefered way to get clearance here. Hopefully it doesn't jump up and bite you on disassembly.Be sue and use a 6point socket on those that you reduced the hex flats of.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
