Old 09-04-2017, 03:51 PM   #1
Bobby Pootz
Bobby Pootz's Avatar
Looking to add aftermarket Tach and need stock fuel gauge
Hello,
Looking to install an Autometer Tach in the Fuel Gauge spot to the right of my Speedo. I can't seem to find the small fuel gauge to replace it for any year past 1980. I've only found ones for 75-80 and 73-78 and I have a 1984 C10.
Would either of those work? I'll be putting it where the clock is currently.
Also, will the circuit board be okay just folded back so I can fit the tach? I'd make sure it couldn't short anything but wanted to know if there's anything I should look out for.
Thanks in advance!
Rob
Bobby Pootz is offline   Reply With Quote
Old 09-07-2017, 07:15 AM   #2
chrismoore701
chrismoore701's Avatar
Re: Looking to add aftermarket Tach and need stock fuel gauge
I heard you can get a small tach and put it where the clock goes from Summit
Chris
_______________________________
1979 Chevy Stepside SPORT
2009 Chevy Silverado, 30 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 09-08-2017, 10:36 AM   #3
SCOTI
SCOTI's Avatar
Originally Posted by Bobby Pootz View Post
Hello,
Thanks in advance!
Rob
I purchased a small fuel gauge from LMC & put it in the blank spot on my 89 duallys cluster when I added a tach. The font was correct for 81-87 gauges.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 09-08-2017, 11:04 AM   #4
PowerdbyChevy79
PowerdbyChevy79's Avatar
very nice...
1976 GMC 35 1-ton dually "Mr. Harvey" - daily driver
1982 C10 Swb fleetside "Lucy" - ongoing project
C/10 Club Texas - HMIC
When the zombies come... I,ll be ready.
PowerdbyChevy79 is offline   Reply With Quote
Old 09-08-2017, 12:24 PM   #5
Mattchu60
Hey SCOTI. Did you have to cut the white cluster housing at all to get the tach in? Seems that the tachs wiring harness needs a hole to pass through on these? Ive wanted to do this for some time but have no idea how hard it is.
Mattchu60 is offline   Reply With Quote
Old 09-08-2017, 01:23 PM   #6
cottonme173
cottonme173's Avatar
I would like to hear more about this. Do you have any Part Numbers for what you bought fuel/tach and how much modification needed to be done?
cottonme173 is offline   Reply With Quote
Old 09-08-2017, 03:41 PM   #7
SCOTI
SCOTI's Avatar
My kit came from here....
http://www.gmsports.com/content/1980...uge-conversion
But the quad gauge set-up was crap. They had mis-matched the font for the 2 upper vs lower gauges. That part of the kit is still sitting in the box. That's when I just ordered the small gas gauge w/the correct font from LMC.
There is a hole already in the plastic housing for the tach wire to slip through & I found another housing that had the fourth opening (clock housing vs a blank).
Repo tachs available here....
http://www.lmctruck.com/NewParts/CC/CCRPT.htm
or here
http://www.classicparts.com/Dash-Par...ducts/349/30/0
The fuel gauge came from LMC but I just checked their catalog online & could no longer find it. I did a quick Google search & found them here....
http://www.classicparts.com/Dash-Par...ducts/349/16/0
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-09-2017, 08:57 AM   #8
abig84
abig84's Avatar
for a easy lazy way of doing it, yeah you can stick it where the clock was. i just removed the clock and put it in its spot and tied off the wires kinda tight to hold it there. only pic i have of it
abig84 is offline   Reply With Quote
Old 09-10-2017, 02:04 PM   #9
Bobby Pootz
Thanks Scoti! That's exactly the info I needed. Much appreciated, that's the gauge I wanted to know about.
Rob
or here
Copyright ©2000 - 2018, vBulletin Solutions Inc.
