Old 09-11-2017, 04:31 PM   #26
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Cam vs mpg
Originally Posted by Sawlog View Post
I know I know, I was just wanting to go 216 216@ .5. 110 lsa. Sounds like I better leave well enough alone.
Going to a 216* can @ .050" really isn't going to give you much 'lope' at all.
You might be able to tell that it has a mild cam, but definitely not the fender shaking crackle/thump/lope that you might be hearing in your head.
Just leave it like it is and enjoy a reliable daily driver with the good mpg you're getting now.
Adam
1969 Chevy CST/10 stepside, Dart Big M 532"BB/TKO600
1965 Chevy Bel Air Wagon, 350/TH350, factory a/c
1961 Chevy Bel Air Sport Coupe, ZZ454/M21
2005 GMC ccsb 1500, 5.3/3.73 G80, tow pkg
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 09-11-2017, 04:57 PM   #27
toolboxchev
Re: Cam vs mpg
Really sounds like you have a great combo working on this right now. I wonder if those cam companies are engineering their product just for an idle sound?
I would hope that engineering's first priority would be HP/Torque at WOT then mileage on light throttle similar to a VVT tuned engine would be. I know some are ground this way yet there is a ton to understand to get there.
toolboxchev is offline   Reply With Quote
Old 09-11-2017, 06:38 PM   #28
Coley
Coley's Avatar
Smile Re: Cam vs mpg
Put a couple of interupter wires into one or two of the spark plug leads.
When you pull up to a light or idle through a parking lot, just hit a switch and ground off one of the spark plugs....that'll give you a rough idle for appearance/sound sake.
Then when you leave the parking lot, click back onto 8 cylinders.
Way cheaper...probably $25 worth of parts....same sound....same roughness.
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 09-11-2017, 08:06 PM   #29
mattfranklin
mattfranklin's Avatar
Re: Cam vs mpg
Except for the getting shocked part when you touch the switch. ;-)
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 09-11-2017, 10:07 PM   #30
garyd1961
Re: Cam vs mpg
I can't believe the guys on here suggesting you should screw up the tuning on a perfectly good running motor to imitate a big cam. Why not just get a set of old heads with some burnt valves, that would really make a rough idle.
garyd1961 is offline   Reply With Quote
Old 09-15-2017, 03:58 PM   #31
Square up 84
Re: Cam vs mpg
I have a 454 with a big Loby Cam in my 86 Silveraydo is not a fun cruising truck.
Square up 84 is offline   Reply With Quote
Old 09-16-2017, 10:15 PM   #32
edhtrd71
Re: Cam vs mpg
Unfortunately lopey idle and good mpg don't exist together. Maybe if you were willing to raise the compression a bunch with the cam swap it might not hurt mpg as bad. Just a theory there, others may say that's bologna.
edhtrd71 is offline   Reply With Quote
Old 09-17-2017, 08:44 PM   #33
Sawlog
Re: Cam vs mpg
Thank you for all the replies, I have a itch to scratch. I ordered a comp xe256. Going to swap out this weekend. I want to see how much differance these faster m0ving valves make.
Sawlog is offline   Reply With Quote
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
