Old 09-09-2017, 05:57 PM   #1
70K10Hunter
70K10Hunter's Avatar
Rams horn manifolds
I thought I saw one time a set of Rams horn manifolds that would accept an A/C compressor, but I believe they were for the 67/72 models. Would they work for a 73/80 with an A6 compressor?
Does anybody know where I could acquire a set?
if in fact they do.
70K10Hunter is offline   Reply With Quote
Old 09-11-2017, 01:34 PM   #2
andyh1956
Re: Rams horn manifolds
I bought a new set of 2 1/2" Chicom Rams Horns at Pate this yr & they both have the bracket on them to mount something, A/C comp or wind mill I don't know...
andyh1956 is offline   Reply With Quote
Old 09-11-2017, 03:13 PM   #3
Malo83
Cruzzzn' Vet
Malo83's Avatar
How about these?
http://www.speedwaymotors.com/Corvet...fold,9133.html
Malo83 is offline   Reply With Quote
Old 09-11-2017, 04:06 PM   #4
MikeB
MikeB's Avatar
The bracket on the 2.5" models is for a mid-1960s generator.
For a pickup you really need the ram's horns with angled outlets to clear the crossmember. However, I don't know if they would clear your compressor, since they rise up much higher than the 73-87 "log type".
Dorman 674201, left side (Right side is 674199)
Mike
82 C10 Custom Deluxe SWB -- original paint, 355/TH350, Vortec heads, GM RamJet 350 roller cam
69 C10 LWB -- Bought in 1989, now my son's
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here since 2000. This is the very first car or truck forum I joined!
MikeB is offline   Reply With Quote
Old 09-11-2017, 08:02 PM   #5
70K10Hunter
thanks guys. Upon further investigation I noticed that my A/C comp has a rear support mount which bolts between the 2nd and 3rd bolt hole and the Rams horn ain't gonna make it. So I guess its the log style or maybe some headers and make spacers for the rear support.
Gotta have my A/C it is Texas you know.
Old 09-11-2017, 10:12 PM   #6
72freak
Rottenwood Garage Member
72freak's Avatar
This is a common misconception. Straight dump 2.5 ram horns clear fine. I put them on every 67-72 I built over the past 20 years. 2x4, 4x4. Now with that said, the kick backs do allow for less of a bend at the start of the exhaust pipe and i will certainly give them a try on one of my next builds!.
2001 Chevrolet 2500HD Crew 6.0
1999 Chevrolet Tahoe 4x4
1999 Harley Davidson Electra Glide
1996 Chevrolet C3500 Ex-cab 5.7
1980 Toyota Corolla "Rock-n-Rolla"
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A, "Hot Rod"
1931 Ford Model A Tudor "Silverback"
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 09-11-2017, 11:37 PM   #7
MikeB
MikeB's Avatar
Interesting. I had a pair of the 2.5" Dormans that would have required a very tight radius bend on my old 69 C10. I am partial to large mandrel bends, and doubt one could be made that tight. The larger the radius the better! However, those manifolds would have worked on a K10, because the engine was mounted farther back.
On my 82 C10, I might have been able to make them fit had I notched the motor mount clam shells, but would have had the same issue with the tight bends.
If the OP needs manifolds, I have these sitting on the shelf. They're for a 96-up 350. I used them on my 82 C10 for a year or so before I switched to headers. What I like about them is they don't have air injection ports. The stub pipes and flanges are 2-1/4".
Mike
Old 09-19-2017, 08:17 PM   #8
GMDad
GMDad's Avatar
Were you able to use the stock pipes from an 82 with these manifolds? I am going to replace the 305 I my 86 and want to remove injection pump etc and those manifolds looked really good on yours.
GMDad is offline   Reply With Quote
Old 09-19-2017, 08:50 PM   #9
MikeB
MikeB's Avatar
No, I modified the head pipes in a 73-87 Heartthrob Exhaust kit using extra pipes and mandrel bends that were included for long wheelbase trucks. But any muffler shop can make the connections.
96-up trucks use a Y pipe with CATs and probably wouldn't fit an 73-87 anyway.
Mike
Old 09-21-2017, 09:43 PM   #10
54Caddy
GM Addicted
54Caddy's Avatar
N2trux has a set of 2.5 ram horns on his truck
..Macís Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 09-22-2017, 06:05 AM   #11
mcmlxix
Collector of Projects
mcmlxix's Avatar
I have a factory 2wd 78 Blazer and asked a friend to swap some 2.5" ram horn manifolds from the old headers. I was in the process of moving so it would have been a perfect time. He came back a week later and said they wouldn't fit.... They were Speedway Motors smoothie that dump straight down...
Rich
1972 K5 Blazer CST Click HERE
Old 09-22-2017, 09:39 AM   #12
MikeB
MikeB's Avatar
54Caddy -- That is a very nice installation, at least on the passenger side. Do you know if he had to notch the driver side clam shell to clear the manifold flange?
And I wonder what the driver's side head pipe bend looks like. On my 82 C10, it would have been a severe bend starting right at the flange to clear the crossmember.
Mike
Old 09-24-2017, 05:10 AM   #13
54Caddy
GM Addicted
54Caddy's Avatar
No he says in thread that he didn’t have to notch motor mounts. Passenger side he did change to a mini starter since OEM style was bad so I’m sure that helped with clearance a bit. Drivers side I’m sure has a crazy bend to it but that’s all just in finding an exhaust shop that knows what they’re doing.
..Macís Garage..
IG:MacsGarage
Old 09-25-2017, 02:11 PM   #14
kacy
kacy's Avatar
anyone have these on their stock height 4x4s?
79 Corvette- 406/7004r Holley EFI
87 V10- 5.7L, Vortec heads, E110026, 410s 35s, 700r4
kacy is offline   Reply With Quote
Old 09-27-2017, 12:51 AM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by 54Caddy View Post
No he says in thread that he didnít have to notch motor mounts. Passenger side he did change to a mini starter since OEM style was bad so Iím sure that helped with clearance a bit. Drivers side Iím sure has a crazy bend to it but thatís all just in finding an exhaust shop that knows what theyíre doing.
Roger Lynsky of RPL built a custom Y pipe and we ran a single 2.5" pipe back to a large mouth CAT followed by a SI/SO Flowmaster with a tailpipe that ran to the rear of the truck. There were no clearance issues, and no crazy bends in the pipe. The sound was nice a smooth till you nailed it and then it talked nasty.
Later when we installed the 4 link, I had to cut the system shorter to clear. Now its just loud, and doesnt sound as clean. I plan to make changes to that soon.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-27-2017, 01:37 AM   #16
mcmlxix
mcmlxix's Avatar
So I have a 78 factory 2WD with a SBC. I used a late model factory mini starter. I have a serpentine belt setup so I should be OK with the ram horn manifolds?
Would you recommend studs for the manifolds? Have a part number? I would guess Dorman should make some...
Rich
Copyright ©2000 - 2018, vBulletin Solutions Inc.
