Old 01-12-2017, 10:54 PM   #126
BLP86
Re: static dropped square bodies with 15s
Here's Mine on 15's 5" Front, 7" Rear
BLP86 is offline   Reply With Quote
Old 01-25-2017, 12:36 AM   #127
SIXTY9CST
What size tires?
SIXTY9CST is offline   Reply With Quote
Old 01-25-2017, 12:37 AM   #128
SIXTY9CST
What size tires?
Old 01-25-2017, 10:25 AM   #129
85/Silverado
85/Silverado's Avatar
Originally Posted by Houston Ben View Post
2/4 drop (springs and shackles) w/ 275/60/15 all around. I think I need to put OG springs back on and get 3" spindles.
What color is your truck?
85/Silverado is offline   Reply With Quote
Old 01-26-2017, 11:15 AM   #130
BLP86
Originally Posted by SIXTY9CST View Post
What size tires?
Sorry for the delay;
Fronts are 215/70's and the Rear are 275/60's. Front wheels are the 6.5in Van Wheels, backs are the 8in rallys
Old 01-26-2017, 03:26 PM   #131
moneyeater
moneyeater's Avatar
4,5/6 drop with BellTech spindles, springs, flip kit and shocks.
15x10 American Eagle 589 rims with 295/50 and 255/60.
Had to grind back the lip on the lower control arm for clearence.
Rides like a gocart and is real fun!
My little US vehicle parts business:
http://www.thegearheaddepot.com/
Come have a look!
81 GMC C 10, Spanish Red
moneyeater is offline   Reply With Quote
Old 01-26-2017, 11:43 PM   #132
Ziegelsteinfaust
That isna sweet looking ride.
Ziegelsteinfaust is offline   Reply With Quote
Old 01-27-2017, 02:27 AM   #133
moneyeater
moneyeater's Avatar
Thank you! My pride and joy for 24 years now!
Come have a look!
Old 01-27-2017, 09:19 AM   #134
Houston Ben
Houston Ben's Avatar
85/Silver,
It is PPG 50775 Cordovan Maroon.
Moneyeater, I love your truck, might have to copy your tire size!
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532
Houston Ben is offline   Reply With Quote
Old 01-28-2017, 10:55 PM   #135
85supersierra
85supersierra's Avatar
I will be joining this thread soon. I plan to loose my current 17's for a set of 15" Ansen Sprints with BFG T/A.
85supersierra is offline   Reply With Quote
Old 01-29-2017, 05:46 PM   #136
Houston Ben
85super,
What don't you like about your 17" rims? I was thinking of going to 17s but not sure. If I don't, I thought about the same style rim you want to go to.
Old 01-29-2017, 11:16 PM   #137
85supersierra
Huston Ben, there is nothing wrong with my 17's. they where in the truck when I bought it. They are Helo Max 6 and look to 4x4ish for me. I am going with the 15's for the classic look. Not to mention a set of 4 rims and tires together cost less than one Schott rim that was my other option.
Old 09-11-2017, 06:29 PM   #138
lilred87
Originally Posted by bbbc10 View Post
mine 5/6 wth 15x8/15x10 rallys
What size tires are you running bbbc10?
lilred87 is offline   Reply With Quote
Old 09-11-2017, 08:42 PM   #139
OK83c10
OK83c10's Avatar
2.5/4 drop with western chassis drop spindles up front and drop leafs springs in the back
OK83c10 is offline   Reply With Quote
Old 09-11-2017, 11:55 PM   #140
MikeB
MikeB's Avatar
Dropped leaf springs? Where did you get them?
I have Beltech dropped hangers and WC shackles on the shelf, but can't decide which set or combo to use for a 2"-3" drop. If I do the hangers I'll need to drop the tank. Using the shackles requires notching a bed support member, which I hate to do.
Mike
82 C10 Custom Deluxe SWB -- original paint, 355/TH350, Vortec heads, GM RamJet 350 roller cam
69 C10 LWB -- Bought in 1989, now my son's
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here since 2000. This is the very first car or truck forum I joined!
MikeB is offline   Reply With Quote
Old 09-12-2017, 08:22 PM   #141
OK83c10
OK83c10's Avatar
I ordered them from the Western Chassis website. Install was easy. I went with these so I didn't have to cut the support for the shackles or go through the trouble of grinding rivets and relocating the hangers. You could purchase the 3" drop leaf springs and remove a leaf to drop it to 4 inches if you don't like the stance. It didn't quite get me to 4" of drop but I'm pleased with the results. I'll put a link below
https://westernchassisinc.com/1973-8...-Leaf-Springs/
Old 09-12-2017, 08:59 PM   #142
wtchop
Junior Member
wtchop's Avatar
5.5/7 drop on 15x7 front and 15x8 rear.
wtchop is offline   Reply With Quote
Old 09-12-2017, 09:25 PM   #143
85/Silverado
A static Drop is not cutting the frame rails?
Old 09-13-2017, 12:54 PM   #144
PowerdbyChevy79
PowerdbyChevy79's Avatar
15x8 rallys all around
1976 GMC 35 1-ton dually "Mr. Harvey" - daily driver
1982 C10 Swb fleetside "Lucy" - ongoing project
C/10 Club Texas - HMIC
When the zombies come... I,ll be ready.
PowerdbyChevy79 is offline   Reply With Quote
Old 09-13-2017, 01:26 PM   #145
Nuckingfuts
You guys with 5/7 drops, is there room for a 15x10 Rally wheel with 275's mounted in the rear?
Nuckingfuts is offline   Reply With Quote
Old 09-13-2017, 05:39 PM   #146
Nick_R_23
Nick_R_23's Avatar
A static drop is just simply a drop that is at a fixed height - it doesn't change. Examples would be drop springs, drop spindles, axle flips, or shackle relocators, once installed your ride height is set. Guys with bags on their truck can raise or lower the suspension height at will.
Check out my Alaska built 78/86 C10 stepside! http://67-72chevytrucks.com/vboard/s...d.php?t=706825
Old 09-13-2017, 09:24 PM   #147
85/Silverado
I see... It's a non adjustable suspension.
Old 09-14-2017, 02:29 PM   #148
aggie91
I'm just glad to be here!
aggie91's Avatar
Yes. We even ran a 295/50-15 on a fleetside...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 09-14-2017, 03:05 PM   #149
Malo83
Cruzzzn' Vet
Malo83's Avatar
My 83, 15x8, 15x10
Malo83 is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
