Old 09-12-2017, 10:02 PM   #1
tgdoumit
Junior Member
Finding the Wheel - 17" 8 Lug Poverty
i am not having much luck finding something similar to this in 17".
wheel vintique is one place i looked and several others. anyone have any good leads? thanks!
1988 GMC Suburban 12 Valve"MOBY"
tgdoumit is offline   Reply With Quote
Old 09-12-2017, 11:39 PM   #2
mongocanfly
Re: Finding the Wheel - 17" 8 Lug Poverty
16s are plentiful in wheels like those. .not finding it in 17...any reason a 16 wouldn't work?
closest thing I could find was a dodge 17in...
Old 09-13-2017, 12:53 AM   #3
tgdoumit
Junior Member
I want the bigger wheel for two reasons. I have new tires off my last truck and I like the idea of more room for brake options. Neither of my axles are gm.
Old 09-13-2017, 03:11 AM   #4
andrewmp6
Cragar makes a soft 8 and d window n 17s and 8 lug.And what are the axles from ?Because there is 2 different 8 lug patterns and if its a 4x4 the hub bore size can very from brands like ford chevy and dodge use different sizes.
Old 09-14-2017, 12:32 AM   #5
tgdoumit
Junior Member
1978 Ford hp Dana 60 and 1996 Dana 80. Not interested in soft 8's or d holes. The 60 will be restudded to match the larger 80 studs too.
I like the classic look, aftermarket wheel not so much.
Old 09-14-2017, 02:29 AM   #6
andrewmp6
If you want steel 17s that look factory those dodge rims are it in your lug pattern,If you want alloy there the h2 rims,Or a set like these http://www.ebay.com/itm/CHEVY-4X4-SR...NYyGlL&vxp=mtr If you changed it over to the metric lug pattern your options go a lot bigger for oem rims from the big 3.
Old 09-14-2017, 03:41 AM   #7
mcmlxix
Collector of Projects
mcmlxix's Avatar
check with
http://www.stocktonwheel.com/heavy_duty.html
Rich
1972 K5 Blazer CST Click HERE
Old 09-14-2017, 08:55 AM   #8
tgdoumit
Junior Member
Originally Posted by mcmlxix View Post
Sending Stockton an email. Thanks!
Old 09-14-2017, 09:48 AM   #9
jocko
jocko's Avatar
Good Lord avoid Stockton.. I had a horrible experience with them.
Old 09-15-2017, 03:40 AM   #10
tgdoumit
Junior Member
What happened?
Old 09-15-2017, 09:27 AM   #11
sweetk30
sweetk30's Avatar
here is what i did for stock look with my newer twist to it .
black d-window rims . blasted and redone white .
conversion lug nuts to hold black plastic nut covers . these hold drw rear center caps from 88-98 body style trucks .
granted i did 16x10 rims . . . but same ideas . and 1 old gm orignal for refrence of my idea/ twist on it .
77-k30lb
79-k30stubby
85-k30lb
85-c10sb
sweetk30 is offline   Reply With Quote
Old 09-15-2017, 09:36 AM   #12
tgdoumit
Junior Member
Those turned out nice. I've only seen em in black before.
Old 09-15-2017, 10:37 AM   #13
mongocanfly
those turned out nice sweetk...
Old 09-15-2017, 05:03 PM   #14
sweetk30
sweetk30's Avatar
i hate the black rim faze . . . why they went white brand new out of the box from black .
77-k30lb
79-k30stubby
85-k30lb
85-c10sb
Old 09-17-2017, 05:57 PM   #15
v30crewcab
v30crewcab's Avatar
I've talked to wheel vintiques on the phone about 17" wheels.they are not real interested in making them. I'm wondering if we started a thread here about it and got a bunch of people that wanted them, if they might start building them? I would love a set on my crewcab, and my 76 pathfinder van.
88 military v30 crewcab shortbed
5.9 cummins, nv4500, 205
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 09-17-2017, 06:02 PM   #16
obijuan
stockton quoted about 1200 for a set of four 17 inch wheels to accept my k30 hub caps.
they take a 16" wheel center then a 17" barrel. make a ring spacer and weld the three pieces together. seems like a pain in the ass to make yourself so the price isnt far out of line for specialty work.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2
1991 V3500 350/4l80/205 60/14 4.10 35 toyos.
obijuan is offline   Reply With Quote
Old 09-22-2017, 10:36 AM   #17
obijuan
For what it's worth, Stockton just delivered a set of wheels after 3 weeks. Exactly how long they told me it would take.
Old 09-22-2017, 07:00 PM   #18
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Did you get the 17s? I called a while ago and they wouldn't even give me a quote and said they wouldn't make them. I plan to use the dodge steel 17" wheels if I ever get to working on the truck again.
Ryan
1976 K30 CC SWB Build Thread
Old 09-22-2017, 09:25 PM   #19
v30crewcab
v30crewcab's Avatar
I would rather get detroits 18" wheels, than stockton. 1K for a set and you can get clips to run hubcabs on them.
Old 09-23-2017, 03:34 AM   #20
andrewmp6
He has a 4x4 would those Detroit rims have a hub bore big enough ?
Old 09-23-2017, 09:37 AM   #21
obijuan
No these were for a customer at the shop. Not my wheels unfortunately
Old 09-30-2017, 09:38 AM   #22
jocko
jocko's Avatar
What happened?
Sorry slow reply. Ordered pc'ed vette rally wheels from them a logn time ago - they arrived flashed over with surface rust in a lot of areas (yes, I had the same reaction...) and, somehow, that was my fault(!) The issue was they hadn't fully pc'ed properly and all the freshly blasted areas that didn't receive the pc were rusted - was almost like the wheels just got a cursory shot and there were a lot of missed spots, especially at the wheel/center joint. Several back and forth shippings and they never really corrected the issue - I ended up treating and touching up with paint. It was just shoddy work to begin with and horrible customer service after the fact.
Copyright ©2000 - 2018, vBulletin Solutions Inc.
