Old 07-10-2015, 10:25 PM   #51
nsb29
nsb29's Avatar
Re: a/c vent box
Originally Posted by NevEno View Post
Any pictures of it installed?
corvette jim posted a complete install on his thread (64 to 66 center A/C vent)
nsb29 is offline   Reply With Quote
Old 07-11-2015, 09:33 AM   #52
nsb29
nsb29's Avatar
Re: a/c vent box
Originally Posted by volkscafe View Post
I'll take a vent box. PM me the total along with your paypal info.
Thanks, Jared
will ship Monday thanks doug
Old 07-11-2015, 09:36 AM   #53
nsb29
nsb29's Avatar
Re: a/c vent box
Originally Posted by MalibuKasey View Post
Im interested in one.
yours is ready to ship also thanks Doug
Old 07-11-2015, 11:27 AM   #54
64chevycrewcab
Active Member
Re: a/c vent box
Payment sent
1961 Apache 10 with side trim
1964 4 door crew cab C20
1966 Suburban with custom trim
1961 K30 with a 4-53T Detroit diesel
64chevycrewcab is offline   Reply With Quote
Old 07-11-2015, 03:12 PM   #55
nsb29
nsb29's Avatar
Re: a/c vent box
Originally Posted by 64chevycrewcab View Post
Payment sent
thanks Doug
Old 07-12-2015, 07:02 PM   #56
nsb29
nsb29's Avatar
Re: a/c vent box
Add me to the list.
yours will ship Monday thanks for the order pm sent
Old 07-13-2015, 08:19 PM   #57
nsb29
nsb29's Avatar
Re: a/c vent box
volkcafe and 64 chevycrucab yours shipped to day thanks Doug
Old 07-14-2015, 08:34 PM   #58
nsb29
nsb29's Avatar
Re: a/c vent box
Originally Posted by RoyL View Post
Add me to the list. Awesome work!
yours will be ready to ship Thursday
Old 07-15-2015, 12:37 PM   #59
MalibuKasey
Artist
MalibuKasey's Avatar
Re: a/c vent box
Payment sent!
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66
MalibuKasey is offline   Reply With Quote
Old 07-15-2015, 09:42 PM   #60
nsb29
nsb29's Avatar
Re: a/c vent box
Payment sent!
got it will ship Thursday or Friday
Old 07-16-2015, 06:47 PM   #61
nsb29
nsb29's Avatar
Re: a/c vent box
payment received pm sent
Old 07-17-2015, 04:11 PM   #62
nsb29
nsb29's Avatar
Re: a/c vent box
Payment sent!
went out to day thanks for the order
Old 07-18-2015, 09:43 AM   #63
nsb29
nsb29's Avatar
Re: a/c vent box
I am now including a template with all orders for those cutting there non A/C dash if you have already purchased a vent box and need a template send me a pm with your address
Old 07-21-2015, 09:35 AM   #64
nsb29
nsb29's Avatar
Re: a/c vent box
MADE IN THE USA
Old 07-26-2015, 10:09 AM   #65
nsb29
nsb29's Avatar
Re: a/c vent box
made in the usa
ttt
Old 07-30-2015, 06:45 PM   #66
earl84
Re: a/c vent box
I got this installed last week, along with corvettejim's AC center vent. Unfortunately, no pics of the exterior completed, but I got some under the dash. It fit somewhat tight, but it did fit, with clearance from the windshield wiper motor, the installed speakers and everything else. I didn't have the cut template, but got it done. Scary cutting up the dash, let me tell you, and the template being provided now is a great addition.
I installed two center 4.5 inch coax speakers using the stock speaker mount cut to screw them onto the old speaker frame. I could modify it some more to gain probably almost an inch total clearance by mounting the speakers as far forward as possible and bending it up towards the windshield slightly. My speakers are 1.9685 (49mm) installed depth. Additionally, my tweeters stuck up above the mounting surface of the coax speaker, so if your choice were flush, it SHOULD clear just fine. But you'll have to do your own measuring, I take no responsibility, just relating my experience, hoping it helps someone out.
Hope the pics show up and help with any questions. Forum is only allowing one pic at a time.
earl84 is offline   Reply With Quote
Old 07-30-2015, 06:47 PM   #67
earl84
Re: a/c vent box
Pic 2. There is a little flexibility to move the radio and vent to allow future AC hose hookup, Vintage Air is next, hopefully.
Old 07-30-2015, 06:49 PM   #68
earl84
Re: a/c vent box
Pic
Old 07-30-2015, 06:50 PM   #69
earl84
Re: a/c vent box
Pic 4
Old 07-30-2015, 06:51 PM   #70
earl84
Re: a/c vent box
Pic 5
Old 07-31-2015, 08:42 AM   #71
nsb29
nsb29's Avatar
Re: a/c vent box
thanks for the pictures the radio is definitely larger than mine and wow I don't believe you got the speakers in there, your radio appears up a little in the back if you lowered it you would have better access to the vent tube thanks again Doug
Old 08-01-2015, 09:51 AM   #72
earl84
Re: a/c vent box
I think the radio looking larger is just because of the angles and close proximity of the lens to the radio. It's a standard size single DIN radio. I merely instAlled the radio tight to the angle of the dash opening hole that the PO had cut the hole. Had to tweak the hole a bit to clean it up and make the mounting sleeve that came with the radio fit. There is PLENTY of wiggle room to move the rear of the head unit down to connect hoses to the vent tubes, so don't let that closeness scare you off from buying this, it will not be an issue.
As for the speakers, if I had started with just mounting them as far forward toward the windshield as possible and bent the old speaker frame up a little more, there would be quite a bit of clearance. I don't think anyone will have an issue with clearance of those center channel speakers either, unless they use really large speakers there. The stock one, or one with similar measurements as the stock one, should easily clear.
Old 08-17-2015, 10:09 AM   #73
nsb29
nsb29's Avatar
Re: a/c vent box
MADE IN THE USA
Old 08-17-2015, 08:59 PM   #74
corvettejim1968
corvettejim1968's Avatar
Re: a/c vent box
MADE IN THE USA
yep that's what I like to see. Had one guy tell me he thought my A/C vent assembly was too much at $300 he said it was worth $150. he has no idea what I have gone through to make these parts by hand here in the U.S.A. you get what you pay for and I will pay for good American parts. Thank you for making these A/C vent boxes.
Hand Made Factory reproduction A/C vents 602-361-6421 http://67-72chevytrucks.com/vboard/s...d.php?t=725354
Faceplate $150
any vent $25
ball mount set $20
ball felt set $20
center vent clip $5
hardware $5
side vent assembly $80
center assembly $270
center assembly with side vents $340
any order over $100 Free Shipping
prices do not include any fees if applicable
orders will come with a template to cut the dashboard and info on where to get your vent balls chromed and how to prep them.
corvettejim1968 is offline   Reply With Quote
Old 08-19-2015, 10:48 AM   #75
nsb29
nsb29's Avatar
Re: a/c vent box
LOL 150 bucks, I had one of them to not counting the time it took to make the mold a lot of work goes in to each air box to make money I need to charge a lot more I do this to help out the other truck enthusiast on this site and a few bucks for some of the stuff I need for my truck
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
