Old 08-19-2017, 11:31 PM   #1
amadioranch
amadioranch's Avatar
Pitting in block/combustion chamber
Pulled the head on my old 235 today due to a blown head gasket between #4 and #5. Was cleaning things up and noticed this pitting only on #5. What caused it and is it a issue?
amadioranch is offline   Reply With Quote
Old 08-20-2017, 06:35 AM   #2
truckdude239
truckdude239's Avatar
Re: Pitting in block/combustion chamber
Cuased by a blown head gasket beeing run for a long time its time for the block to be re decked or replaced if the pits are too deep a new head gasket will never seal properly with the pitting tbere
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 101kmiles
2002 Honda Accord 4 door With 275k(sisters car)
1998 Honda Accord 4 door with 318k(brothers car)
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-20-2017, 08:45 AM   #3
cg285
it's been a long time but if i remember correctly the head gasket does not follow the cylinder - as in it's not a round opening. lay the gasket on the block and if it fits around that area you are good to go.
cg285 is offline   Reply With Quote
Old 08-20-2017, 09:16 AM   #4
Bigdav160
Bigdav160's Avatar
What caused it
Detonation from running hot.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-20-2017, 09:43 AM   #5
YoungPup1977
Head gasket does not cover that area.....deck and align bore the block to see where you are...good luck.
YoungPup1977 is offline   Reply With Quote
Old 08-20-2017, 10:04 AM   #6
mongocanfly
you can see the same pattern on adjacent cylinders but I'd deck it for good measure but it may be ok as is....here's 235 head gasket..
Old 08-20-2017, 10:32 AM   #7
cg285
and we are line boring it because??????????
Old 08-20-2017, 10:37 AM   #8
amadioranch
Thanks for the input guys! The pitting is directly below where to combustion chamber in the head is, not on any head gasket sealing area.
Think im going to slap a new head gasket on it and see what it does. If it blows out the gasket again im only out a little labor and $25 in a gasket. Id prefer not to pull the motor at the moment. If it blows again then ill pull it and do the whole shootin match. Its in a old 1949 2 ton that im only going to put a couple hundred miles on a year. Like to not put alot of money into it. Another factor is that I believe that this motor was rebuilt not long before I purchased it. It has strong compression (155lbs) and I can still see crosshatching on cylinders.
Old 08-20-2017, 01:12 PM   #9
YoungPup1977
so you ask me why ? I deck and align check all engines....dont you ??
Old 08-20-2017, 07:09 PM   #10
cg285
no... especially if i'm only replacing a head gasket. i don't machine anything that is not necessary
bty i think you said "Head gasket does not cover that area.....deck and align bore the block to see where you are...good luck."
did i miss something?
Old 08-20-2017, 09:10 PM   #11
truckdude239
Sorry was thinking about small block v8 if the gasket seals on a smooth part id let it ride
David fuller
Old 08-20-2017, 09:21 PM   #12
YoungPup1977
are you challenging me on this or you just want to show you are the expert here ? not here to argue any thing.....just the way folks do things because I do not do things twice....so go ahead and do things your way, I could care less....
I dont miss anything...you can....
Old 08-21-2017, 07:59 AM   #13
cg285
point is some people here don't have much of a clue so now some may think they can't replace a head gasket without line boring the block.
Old 08-21-2017, 05:22 PM   #14
YoungPup1977
LOL!!!! OK...maybe I get a call from several machinist thanking me for the work....LOL!!!!!
Old 08-21-2017, 07:39 PM   #15
nonstop
Back on topic..... just saw 155 on the compression test. Is that in all cylinders? Might be worth throwing a head gasket at it. Then just keep an eye open for a cheap 235 to replace this one when/if the time comes and you can build it at your leisure.
nonstop is offline   Reply With Quote
Old 08-22-2017, 10:29 AM   #16
GRX
GRX's Avatar
Yep. Obvious blown head gasket. That pitting is actually caused by 'cavitation' from compressed coolant I would say.
Not to scare you. Be sure to check radius of head combustion chamber for cracks too. Probably more than half the 235 heads I magnafluxed had one there. If not to water yet they can be in future.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 09-03-2017, 12:55 AM   #17
YoungPup1977
So would it be a good practice to have the head checked before replacing the head gasket ? most likely the answer would be YES.....
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
