Old 08-26-2017, 10:38 PM   #1
81turbota
Alternator bolt broken off in head
Well guys, this happened. I blame the cheap chrome alternator bracket on putting too much downwards pressure on the alternator.
Anyways, it's broken off well below the surface. I would normally weld a nut onto it but it's sunk in 1/8-3/16". I have had terrible luck with easy outs, do you all have any other ideas?
Thanks!
81turbota is offline   Reply With Quote
Old 08-26-2017, 11:02 PM   #2
Captainfab
60-66 Nut
Re: Alternator bolt broken off in head
If you have a wirefeed, I would build up the end of the bolt using multiple 'tacks' until you build it up enough to be able to weld a nut onto it. Otherwise, you will likely just have to drill it out. Start with say a 3/16" bit and work your way up until all you have left is the threads and then pick them out and run a tap in the hole. I know easier said than done.
Old 08-26-2017, 11:13 PM   #3
mongocanfly
drill and ease out...I know...it sucks....
if you try to drill the bolt out make sure your centered and straight on the broke bolt or your likely to cause more damage
Old 08-26-2017, 11:32 PM   #4
truckster
truckster's Avatar
I'm with CaptainFab. When I have a bolt broken off below the surface I'll drill out a nut of the same diameter as the bolt to about a 16th of an inch from the other side and hold it against the surface as a guide for my wife feed. It lets me build up the weld on the bolt without having to worry so much about hitting the sides of the opening.
Looking at your pic I'm pretty confident that it would work for you.
If I didn't build it or fix it, it's probably not mine.
truckster is offline   Reply With Quote
Old 08-26-2017, 11:38 PM   #5
81turbota
Thanks gentlemen! I have a MIG and will try it tomorrow.
Old 08-26-2017, 11:55 PM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
Left hand drill bits almost always work, but if it won't come out with that, I like Irwin bolt extractors. You'll already have a hole to work with. I'm not a fan of regular ez outs.
Adam
1969 Chevy CST/10 stepside, Dart Big M 532"BB/TKO600
1965 Chevy Bel Air Wagon, 350/TH350, factory a/c
1961 Chevy Bel Air Sport Coupe, ZZ454/M21
2005 GMC ccsb 1500, 5.3/3.73 G80, tow pkg
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 08-27-2017, 05:05 PM   #7
68gmsee
Active Member
68gmsee's Avatar
The good thing about this broken bolt is that it broke due to either defective bolt or vibration or both. It wasn't because it was frozen in place so it should come out fairly easy with above suggestions. Heat and a little penetrating oil like Blaster or Liquid Wrench will help also.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 09-03-2017, 04:59 PM   #8
81turbota
Success.
I delayed since I was waiting to borrow the angle drill from a coworker. It saved me from having to remove the radiator shroud.
Spun right out after I drilled a 3/16" hole through it.
Thanks everyone!
James
1971 Blazer 350/SM465/NP205
1966 Chevelle 468/TH400
2009 Corvette Z06 built LS7
Old 09-03-2017, 07:38 PM   #9
RustyBucket
RustyBucket's Avatar
Great, I love a story with a happy ending!!!
Dad always said, "Son, WISH IN ONE HAND, and ......."
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
'66 Plymouth Belvedere City of Miami cop car clone
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- shop ornament, needs resto.... SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, needs resto...SOLD!!
RustyBucket is offline   Reply With Quote
Old 09-03-2017, 09:37 PM   #10
truckster
truckster's Avatar
Thanks for coming back and letting us know how it turned out.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
