Old 09-07-2017, 04:46 PM   #1
'63MurderTruck
'63MurderTruck's Avatar
327 overheating
I've got a 327 that's been running great for a couple of months now...
The engine temp usually runs around 185(night), and 210(day) when it's about 90 plus degrees outside. It has a 185 Thermostat.
The outside temp is 83 today, and after going on a quick 5 mile round trip errand the engine temp hit 235.
Any ideas on why it's getting hot all of a sudden?
'63MurderTruck is offline   Reply With Quote
Old 09-07-2017, 05:05 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: 327 overheating
Too many things can cause overheating. The list is fairly long but start with the easiest and cheapest first (not necessarily in order).
-Radiator cap
-Collapsing lower radiator hose (weak or internal spring rusted out).
-Clogged radiator or defective
-Sticking thermostat (test it in an old pot on the stove)
-Head gasket or crack in the head
-Not enough coolant (install an overflow tank)
-Radiator fan clutch bad (if using one)
-Install a shroud if there isn't one
There may be other causes but this gives you an idea.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
