Old 09-10-2017, 05:57 PM   #1
65truckowner
65truckowner's Avatar
68 chevy 3 speed
I have a 68 chevy 3 speed transmission in my 65 I am building. I pulled it today to check the bearings and gears and noticed the piece around the front input shaft where the throw out bearing rides was cracked right behind the throw out bearing. CAn I weld this or is it cast, If I can not weld it where would I get a replacement piece. I only have a wire welder.
65truckowner is offline   Reply With Quote
Old 09-10-2017, 10:26 PM   #2
geezer#99
geezer#99's Avatar
Re: 68 chevy 3 speed
REplace it.
It's called a bearing retainer.
If it's a saginaw these guys have some. If it's a muncie they might have one (not listed).
http://www.garagemotorsports.com/muncie.htm
Old 09-10-2017, 10:57 PM   #3
crazy longhorn
Fabricate till you "puke"
Just be aware of the center hole sizing on the bell housing....your 65 was 4.687(4 11/16"), vs the 68 -up truck bell, that was 5.125. The bearing retainer for a saginaw car trans, will fit your 65 truck bell. Same bolt pattern, just the diff in the OD of the retainer Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-11-2017, 07:28 AM   #4
65truckowner
Thanks.
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
