Old 09-10-2017, 06:51 PM   #1
northerngmc
northerngmc's Avatar
Exhaust manifold torque procedures
The left cast exhaust manifold on my 396 in my 1968 C20 cracked/broke. I have replaced the manifold but I am wondering about the torque procedure.
I have tightened them all up, using a pattern to equally apply torque. Should they be tightened hot or cold or maybe both?
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 09-11-2017, 10:05 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Exhaust manifold torque procedures
It's not a critical part. I've always just torqued the bolts down equally and double check them after I've run the engine to operating temperature. Specs say 25 ft lbs.
The important part is to make sure there aren't any high/low areas of the mating surface. The couple of times I've bought a new manifold I've had to have them resurfaced to make sure they were completely flat.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 09-11-2017, 06:44 PM   #3
northerngmc
Thanks. I warmed it up and re-torqued today.
Blaine
Old 09-11-2017, 07:53 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Forgot to mention that I don't use gaskets on the sbc stock cast iron manifolds, however, I do use one on my 250 six cylinder since the intake and exhaust are combined.
06 Trailblazer
Old 09-11-2017, 11:35 PM   #5
northerngmc
I did not use a gasket. I was surprised to learn that GM did not use gaskets.
Now I just need to find a plug that will fit the hole in the back of the manifold where smog equipment would go. 3/8" NPS plugs fit great in the holes on the top, but 3/8" is too small and 1/2" NPS is too large for the hole on the back. On my way to work tonight I picked up a #8 brass flare plug that I hope fits.......
Blaine
Old 09-12-2017, 06:14 PM   #6
northerngmc
So I think a combination of me not being familiar with pipe measurements and the bin at the parts store having the wrong size in it has caused me great pain over a small issue.
So I found plugs in the 3/8" pipe bin that fit the holes above each cylinder on the exhaust manifold. But these 3/8" plugs were too small for the hole near the exhaust dump and 1/2" was too large....... hummmmmmmm and they had nothing in between.
Turns out the plugs in the 3/8" bin were 1/4".......... and then when I went to a different store and bought a 3/8" brass pipe plug it fit the rear hole just fine.
Blaine
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
