Old 09-11-2017, 09:24 PM   #1
Mgicm
Corvette motor question
So picked up a 50 ad half ton which I see now is going to be a project. Truxk.has a vette motor and trans. Has a painless wire harness. Truck runs well but no lights at all! No headlights nor taillights. Dumb question.. how do I wire this..get a separate fuse panel and wire that up independent of the factory and painless wiring? Thanks
Mgicm is offline   Reply With Quote
Old 09-11-2017, 09:39 PM   #2
mr48chev
mr48chev's Avatar
Re: Corvette motor question
Doesn't sound like a Corvette engine issue at all It sounds like gotta find the right wiring diagram for the wiring kit that is in the truck and sit down and study it.
Link to painless wiring manuals http://www.painlessperformance.com/manual
Take a good high quality photo of the fuse panel and someone might be able ID it and shorten the search a bit. Hopefully the guy who put it together just got it running and quit and it is simple this wire goes here and this wire goes there and oh look the lights work deal.
If you can't fix it with a hammer, you have an electrical problem.
My ongoing truck projects:
Old 09-11-2017, 09:54 PM   #3
Mgicm
I didn't get under the dash much as I had to work but I didn't see a fuse panel other than the one connected to the wiring of the vette brain and harness. Guess I need to look closet under dash I suppose.
Old 09-11-2017, 10:34 PM   #4
mongocanfly
fuses on firewall underhood....
mongocanfly is online now   Reply With Quote
Old 09-11-2017, 10:38 PM   #5
Mgicm
I swear there is absolutely nothing on the firewall original. If it's not there..what's my options? Sorry for the basic questions..I assume a basic wiring panel.
Old 09-11-2017, 10:44 PM   #6
mongocanfly
there's a lot more to it than just hooking up a bunch of wires...I'd suggest getting a good quality replacement harness...that way all your truck wiring will be new and updated..not a rotten bunch of necked wires..and the unknown.....you say a vett engine but I don't know if your referring LS or smallblock
is the painless harness just for the engine or the whole truck?
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
