12-28-2017, 05:35 PM | #1 |
Winter soft tops
Anyone out there still run there soft tops in the winter time?
Would like to see some pics! |
01-03-2018, 11:20 AM | #2 |
Re: Winter soft tops
Lol.. Nobody does? Well, except for myself..
01-03-2018, 01:17 PM | #3 |
My buddy and I both run them year round. For the most part our Blazers sit over the winter unless it is a nice day. Both are parked outside as well. This winter started out pretty mild so we were still wheeling late this year.
Chevy Runs Deep. 1956 210 LS1 TH350 3.31 Posi 12 Bolt 1969 Z/28 5.3 T56 3.73 Posi 12 Bolt 1973 Nova SS 355 TH350 2.73 Posi 12 Bolt 2000 K2500 Suburban LS 6.0 4L80 3.73 G80 2005 K2500HD CCSB LS 6.0 4L80 4.10 G80 2010 2SS/RS Camaro LS3 T56 Aqua Blue Metallic |
01-03-2018, 02:03 PM | #4 |
Hope thats not a picture of what you call winter. Been -32.8 F here lately with lots of snow on the ground.
01-03-2018, 05:39 PM | #5 |
In that spot right now I would venture there is at least 2 feet of snow. It will probably be pushing June before we can make it back there.
01-04-2018, 10:34 PM | #6 |
Haven't had the hard top on my truck in years. (But it does live in the garage!)
01-09-2018, 09:11 PM | #7 |
I’ve had my soft top for 2 winters, and I’ll never go back to hard top. You just don’t wanna let it get past a foot deep on the top and be careful with the windows, other than that I think it does fine. My hard top was junk so I don’t notice any difference in the heater.
01-09-2018, 11:18 PM | #8 |
Not a Bronco - nice rig. I especially like your graphics.
How does your soft top do at keeping the wet out? I'm not too concerned about the cold, but I'd rather keep water on the outside.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
01-09-2018, 11:56 PM | #9 |
It keeps the wet out pretty good, but it’s not perfect. It has flaps above the windows the window that you have to mess with sometimes. It keeps water out fine when parked, but when moving in heavy rain a small amount water will find its way in, but it’s doesn’t bug me much. Probably not good for a rainy climate but I love mine
01-10-2018, 12:56 AM | #10 |
My climate is pretty much the same as yours, and although I have a good single-wall top I think I'm going to save my pennies and buy a soft top.
01-10-2018, 05:48 PM | #11 |
I just recently bought my soft top in sept. and it doesn't leak one bit. Heavy or light rain.
01-10-2018, 06:14 PM | #12 |
How is the wind noise on the highway?
01-10-2018, 08:32 PM | #13 |
Not bad at all but when you roll up the sides it flaps a bit but I’d say that should be expected
01-11-2018, 10:58 AM | #14 |
I would say its not much different than a hard top but the flapping of the soft top is not to bad. You can still have a conversation with someone with out yelling. Definitely worth the investment IMO...
01-21-2018, 05:04 PM | #15 |
just got my birthday present from last year put on
01-30-2018, 12:12 PM | #16 |
Finally getting mine posted. Drive her everyday..
01-30-2018, 12:13 PM | #17 |
apparently the image didn't work. lol...
02-02-2018, 03:09 PM | #18 | |
02-04-2018, 11:22 AM | #19 |
sorry! it wont let me pm photos, heres some pics. i just replaced the softopper aluminum square tube with .125 wall steel tubing and then cut reliefs so the mounting plate would sit flush then i cut the large box tubing and welded her up. i used that big box tubing cause i didnt actually know how i wanted to mount it at the time i built it.. took me like 10 months till i got around to buying the basket from a jeep part out and building the rack itself (1.5 OD .125 wall)which i had a friend bend cause ive never bent tubing. its nice though, gets a ton of looks
02-04-2018, 07:46 PM | #20 | |
02-04-2018, 10:53 PM | #21 |
are gonna cut the bottom of the top a bit? or just deal with the extra gap?
02-05-2018, 12:32 AM | #22 |
02-06-2018, 08:13 PM | #23 | |
02-06-2018, 09:39 PM | #24 |
I did everything except the tube bending and final tube welds, im not good enough to do bending but I could’ve done all the welding, but I just let the fab guy finish it cause I wanted it done lol. And I don’t miss the hard top either!!
02-17-2018, 11:12 PM | #25 |
off subject.... what do yall do for security of your radios with soft tops?
