Old 09-29-2023, 12:07 PM   #26
Joyridin
Re: went cheap on the door seals
Originally Posted by CKfan View Post
Some have suggested buying the Honda rubber so I checked a couple of the sites listed either "no longer available" or out of stock or don't ship.
Called a couple not so local wrecking yards, said you have to come check yourself and/or we don't have inventory records. As fun as driving wrecking yard to wrecking yard which are few and far between here and have no "inventory records" which means you go on a prayer, at $6 a gallon I'll pass.
Local Honda dealer, Oxnard DCH Honda parts dept. want $125 "each" for black the 2dr door seals. That is pricey!
Part #72315 SVAA01 ZA Right side
Part #72355 SVAA01 ZA Left side
Hondapartshub.com (does ship)
Product Description Price Quantity Total
Seal, R Front Door Opening *NH167L* (Graphite Black)
Product ID: 72315-SVA-A01ZA
$59.08 Quantity $59.08
Seal, L Front Door Opening *NH167L* (Graphite Black)
Product ID: 72355-SVA-A01ZA
Subtotal Amount: $118.16 with shipping $135
Thanks to the info from others I have a set ordered.........reluctantly.
I got mine from Hondapartshub.com, which is David McDavid Honda.
Joyridin is offline   Reply With Quote
Old 09-29-2023, 01:18 PM   #27
CKfan
Same here, as noted above
CKfan is offline   Reply With Quote
Old 10-04-2023, 02:33 AM   #28
Richard
Have pair of these in route. Thank you for the link. The Precision push on door seals have been on truck for more than a year and still require slamming the door. Hope these will fix the issue.
Richard
Old 10-04-2023, 03:38 AM   #29
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
So what year civics are we talking about? '06-'11 coupe?
desert-rat is offline   Reply With Quote
Old 10-04-2023, 03:43 AM   #30
desert-rat
Originally Posted by jumpsoffrock View Post
My town has one "pick your part" and I go every month or so, I'd be lucky to see one 06-11 civic coupe every 6 months and (yes I'm counting) so far 1 out of 4 have had a sorta-usable set(one small tear), the other 3 were in shreds.
I'll always be on the lookout.
You must not be in so-cal to only have one salvage yard. There's like a dozen around me here. Some you pull, some they'll pull.
Old 10-04-2023, 03:57 AM   #31
Richard
There are a few not to far from me. I have not visited in years and do not bother. The piranha's strip anything worth while before I can get to them. My brother in another state visits yards near him and I can get parts I need for 1/4 the price, including shipping to me.
Richard
Old 10-04-2023, 12:08 PM   #32
cericd
cericd's Avatar
Are these Civic seals from a 2-door or 4-door model?
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 10-04-2023, 02:38 PM   #33
leddzepp
Moderator
leddzepp's Avatar
2 door.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 10-04-2023, 10:17 PM   #34
jumpsoffrock
No I'm not, We had three self-serve in 2010, two by 2012, and one afterwards. I love going to Ontario; back 7-10 years ago I had made an effort to visit about 6 of the yards spread through LA.
jumpsoffrock is offline   Reply With Quote
Old 10-07-2023, 02:01 AM   #35
Richard
The new Honda seals arrived today. Was anxious to see how they fit. I peeled the Precision press on seal off the drivers door and threw the new seal on. I spent quite a bit of time adjusting the door and the pinch weld mounting point for the Precision seals and still had to slam the doors. Door closes real easy now. I think the Honda seals may be a bit loose the way my door is adjusted. Should be easy to tighten them up a bit.
Richard
Old 10-10-2023, 10:55 AM   #36
loudchevy
Active Member
loudchevy's Avatar
I just got my Honda door seals in the mail yesterday and threw one of them on and it fits perfect. I don't have any experience with the LMC or Precision, but the Honda seal installed in less than a min.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 10-10-2023, 11:36 AM   #37
MikeB
MikeB's Avatar
Please post photos of the Honda seals installed. The used ones I tried had a "flap", for lack of a better word, that was unsightly to say the least.
Also, the Precision push-on seals should be installed a little long. In other words, a little more length than it looks like you need. Just bunch them up a bit as mentioned above. And pay special attention to all four corners to make sure they are snug.
If you stretch them tight and cut them perfectly, they WILL eventually "grow" a gap at the bottom.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 10-10-2023, 01:48 PM   #38
loudchevy
Active Member
loudchevy's Avatar
I assume you're asking for a pic from inside the cab. I already pulled the one off that I installed and didn't take any pics from the inside. Here are a couple pics of the outside. Maybe someone else can posted the inside or I can get an inside pic in the coming days when I work on the drivers side door.
Scott
2003 Tahoe Stock
Old 10-12-2023, 02:01 PM   #39
CKfan
Just got back from a trip and the Honda seals were waiting in a box. Unpacked and will leave out a while so they can un-crumple.
The "flap" on the them doesn't seem to be much bigger than the corners on the LMC ones (IMO)
Old 10-13-2023, 11:02 AM   #40
MikeB
MikeB's Avatar
Maybe a pair of those is in my future. Much nicer looking than the junkyard pair I tried.
Mike
Old 10-15-2023, 06:33 PM   #41
CKfan
I must admit, I was very skeptical but I just installed the door seals today.
Incredible!!!!
Easy to install and they fit perfectly, no trimming. Whoever thought to use a Honda Civic seal is a crazy out of the box thinking genius.
I adjusted my doors (again) after removing the LMC brand seals and had my doors singing with two clicks. Installed the Civic seals and absolutely no issue.
Now I understand what people were referring to when they mentioned the "flap" on these seals. Actually really looks good on the bottom channel and crates a nice reveal on the doors (IMO).
Good luck out there
Old 02-29-2024, 04:03 PM   #42
CKfan
Place I have found be the cheapest. 7 sets so far, all good. (shipping adds around $17)
WWW.hondapartspartshub.com
Part Number Part Name Price Quantity Total
72315-SVA-A01ZA Seal, R Front Door Opening *NH167L* (Graphite Black) $59.08 1 $59.08
72355-SVA-A01ZA Seal, L Front Door Opening *NH167L* (Graphite Black) $59.08 1 $59.08
