04-11-2018, 09:18 PM | #1 |
Drip Rail Fabrication
Spent last week in Rock Hill SC for a metalshaping workshop. My project was going to be making a section of drip rail to match a section cut from a vehicle.. I was going to use the bead roller but any attempt showed distortion was difficult to control. Just to clarify where this is situated, this is welded along the outside of the A-pillar with the tail comprising part of the windshield opening.
After looking at some of the home made Pullmax dies others had brought, I think eliminating the deformity can be best addressed by making dies for the Lennox (Pullmax). Here's what we started with, a section of 18 gauge (to match OEM) and folded the lip that will form the outside face of the drip rail.. Next, a die is used to add the joggle seen at the bottom, and a clamped-on guide prevents the flange from wanting to move skyward. Next operation is to add the slight bit of radius to the front face of the drip rail. Here's our die configuration for this step.. Shown here with the original cross-section piece...
Robert Last edited by MP&C; 04-11-2018 at 11:22 PM. |
04-11-2018, 09:26 PM | #2 |
Re: Drip Rail Fabrication
Our first task tonight was to modify die set #2 from last night so it would also tighten up the reverse joggle.
Next, Die set #3 for adding the remaining folds. A partial bend is done in the magnetic brake, and then the die set forms them more accurately. Before: After.... Comparison: I like this method much better, looks to be more easily repeatable with better consistency.
Robert |
04-11-2018, 09:46 PM | #3 |
Post Whore
as usual...your skills and work is unbelievable and outstanding.....that's amazing....
04-11-2018, 10:55 PM | #4 |
Thanks Greg!
Robert |
04-11-2018, 11:33 PM | #5 |
That is just so cool.
04-12-2018, 09:43 AM | #6 |
Another superb piece of work, Robert!
04-13-2018, 12:43 AM | #7 |
meowMEOWmeowMEOW
really going the extra mile on the fab!
04-13-2018, 07:18 AM | #8 |
Thanks for the comments guys. I had tried to form these awhile back using the bead roller and it was rather inconsistent in that process. These results using the Lennox keep my OCD in check..
Robert |
04-13-2018, 09:51 AM | #9 |
how are you making your dies? wire EDM?
04-13-2018, 10:01 AM | #10 |
4140 oil hardening 3/4 stock, cut SLOWLY on the bandsaw while using plenty of lubricant stick.. and welding where needed..
Robert |
