Old 06-10-2019, 04:49 PM   #1
1971gophercatcher
71 c10 Lower A arm location correct?
C10 Nation!
I rebuilding the entire front end stock. Rebuilt upper and lower control arms including shaft assemblies. I have installed both lowers and lined up the rivets with the forward divots on the shaft assembly.
After installation I noticed that there is 1/2” difference between the two lower control arms in relation to the crossmember. Is this a problem? If so, what is the solution?
Please see pic’s.
1971gophercatcher is offline   Reply With Quote
Old 06-11-2019, 10:32 AM   #2
michael bustamante
michael bustamante's Avatar
Re: 71 c10 Lower A arm location correct?
make sure the guide nubs on the lower control arm pivot shaft are lined up and seated correctly. ive never noticed a half inch difference before.
1967custom
michael bustamante is offline   Reply With Quote
Old 06-12-2019, 11:46 PM   #3
1971gophercatcher
Thanks for your help. Upon further investigation I received two different shaft assemblies that were causing the 1/2” difference. The numbers on the boxes matched but one of the shafts was definitely not the right one. Parts store messed up and they are exchanging for the right one.
Lesson learned: The parts in a box do not always match what is labeled on the box. Double check part numbers on everything before install!
