Old 10-02-2012, 12:05 PM   #26
motornut
78K & 79C Jimmys
motornut's Avatar
Re: rear axle locking up and popping
I wonder how many blew them up adding the additives designed for use in limited slip differentials
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 10-02-2012, 12:10 PM   #27
lowrodderchev
lowrodderchev's Avatar
put the gasket on early this a.m. when i get out of work i'm gonna add my oil cross my fingers say a prayer throw my lucky underware on go for a drive and hope its ok
lowrodderchev is offline   Reply With Quote
Old 10-04-2012, 01:02 PM   #28
Berg
You know, i had 2 of these Gov-locs blow up on me in the past. The first one just came apart under normal driving. It actually dropped out the cross shaft and ruined the carrier and side gears. The second one was an actual differential explosion with only 33"s on it but I was beating on it pretty hard when it came apart so it is my own doing. I had blown the spiders clean out of it, the weights were totally gone and I had snapped the pinion gear when the carrier locked everything up and blew some teeth off the ring gear in the process. I also managed to snap an axle and had it jammed in the case. When I took off the rear diff cover all the parts came out of it and the diff popped out without tools!
1970 Chevelle SS396
1984 K5 Blazer -First Truck!
1999 Big Block K2500 'Burb
Berg is offline   Reply With Quote
Old 10-05-2012, 12:03 AM   #29
lowrodderchev
**** now im worried its been ok so far but sounds like these things are crap
Old 10-05-2012, 02:20 AM   #30
tobiahr
tobiahr's Avatar
the last differential i replaced was a non g80. the previous owner had rebuilt it incorrectly and it ate the spider gear bushings, destroying just about everything else inside. bottom line is the g80s are not known for their strength under extreme circumstances but neither are the standard open diffs. if you are looking for higher strength on a corp 10 bolt you will have to go aftermarket. if you are looking for daily driver strength the g80s will do just as well as the open diffs.
tobiahr is offline   Reply With Quote
Old 10-05-2012, 10:17 AM   #31
lowrodderchev
Mine is the 12 bolt g80 I know a guy who has a 3/4 ton suburban 8 lug axles he wants $300 for front and back is it worth it or should i try putting better stuff in my axle?
Old 10-05-2012, 11:23 AM   #32
68Timber
I know the pieces fit
68Timber's Avatar
They're not total crap. As long as you don't abuse it, it'll hold up fine. Don't spin the tires unnecessarily, street OR dirt. Keep what you have and if it ever blows you can upgrade to a Lok-rite. They are inexpensive, stout, and supposedly easy to install.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-05-2012, 04:48 PM   #33
lowrodderchev
thanx BRUISER, i'm good for now but i own a couple of get-e-up and go cars so i'm use to a led foot. i heard those lok rites are pretty expensive, any other suggestions on something that will let me haul ass around corners and drive it like i stole it?
Old 10-05-2012, 05:13 PM   #34
Dunenutt
Newbee
Dunenutt's Avatar
Smooth, no noise, and tough as nails!
http://www.eaton.com/Eaton/ProductsS...als/PCT_221471
Dunenutt is offline   Reply With Quote
Old 10-05-2012, 05:38 PM   #35
lowrodderchev
that is nice but DAM $440.00 plus install ouch
Old 10-05-2012, 06:55 PM   #36
Dunenutt
Newbee
Dunenutt's Avatar
Ya, they are a little pricey. I have owned several of them ( many in 4x4's both axles), still have 3. The best thing about them is you never know it's there, until you abuse the skinny pedal A Lockright, or Detriot will constantly remind you that it is there. Pop, crunch, bang, chirp, ect.
