09-08-2003, 06:54 PM | #1 |
T-case adaptor Q
I have a friend who is installing a TH400 into his 4x4, but isn't sure yet which t-case has. He needs an adaptor. Will the same one mate his 400 to a 205, 203, 208?? He will be verifying his t-case soon to purchase an adaptor, but if it fits all NP cases, does anyone have one, with the sleeve, to sell? Thanks!!!
69 GMC K10 ..some restoration required....still.. Last edited by Class of 69; 09-08-2003 at 07:12 PM. |
09-08-2003, 07:10 PM | #2 |
Basically, the adapters are all different. Any time you have a different t-case OR transmission, the adapter changes. You need the adapter that goes with your particular t-case/tranny combination. With an NP205/TH400, no sleeve is used. The tranny output shaft engages directly with a female input gear in the transfer case (32 spline).
Tim |
09-08-2003, 07:15 PM | #3 |
OK, I should have also mentioned the TH is out of a 2wd. I'm assuming he will also need a different tailhousing, and maybe an output shaft ??
69 GMC K10 ..some restoration required....still.. |
09-08-2003, 09:31 PM | #4 |
I have a brand new TH400-205 adapter available if your friend is interested.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
09-08-2003, 10:56 PM | #5 | |
09-09-2003, 07:21 PM | #6 |
I didn't see him at work today, but I know he had a TH350 in it before, so I assume that is the t-case he intends to use with the TH400. kwmech, why don't you PM me with what you have, and a price, and I can give it to him next time I see him. Thanks
09-12-2003, 07:32 AM | #7 |
If you get a NP205 that was coupled to a manual or a TH350, you will have to buy an aftermarket adapter to fit it. You cannot just change the input gear and shaft since the bearing housing and input shaft was bigger on a 205 that had a TH400.
09-12-2003, 09:38 PM | #8 |
You can put the parts in AFTER you machine out the front of the case for the larger bearing, been doing it for every bit of 10 years now because of the rarity of the 400/205. Never heard of any aftermarket adaptors myself.
09-12-2003, 11:12 PM | #9 |
I've heard of Advance Adapters that sells many kind of adapters that can couple trannys and NP's together that normally didn't come that way from the factory, without any mods to the Transfer case. They are very pricey though.
09-13-2003, 01:22 AM | #10 |
The adapter that AA sells for this conversion is a new input gear, the larger bearing and an exact copy of the GM adapter. You do have to disasemble and machine the case out for the larger bearing just as kwmech says.
09-13-2003, 06:38 AM | #11 |
Thanks for the correction. I guess I didn't look at all the footnotes on their site. Sorry
