12-24-2017, 09:54 AM | #1 |
46 Crash box 4 speed
1st gear and first gear idler -- must have hit them hard under stress to downshift into first
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 12-24-2017 at 09:56 AM. Reason: words |
12-24-2017, 09:55 AM | #2 |
Re: 46 Crash box 4 speed
3 more pics
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
12-28-2017, 11:17 PM | #3 |
Fabricate till you "puke"
Its hard to say, from the pics....but if no teeth are totally missing, I would clean it up, dress the teeth that mesh together(die grinder). Just take the burs off. Then do bearings & seals....longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-29-2017, 04:59 PM | #4 |
Agree, I believe it is a good trans to keep. I have 2 spares and run one in the 46 3/4 ton.
thanks
