Old 09-04-2015, 01:30 AM   #26
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Hooker 68-72 big block Chevelle headers fit my 69 C10
I have a 4" - 4" drop with a big block on factory small block springs. The collector flanges are 2-1/2" off the street. I'll post some pics tomorrow...If you plan on using your truck for a daily driver, these long tubes wont last. I have metal inserts in my springs up front as well as a half coil cut off the bottoms. Its stiffer than the 2" drop springs. I did that to clear the 30" BFG 60's I had at that time. I have 5" wide, 28" Mickey T's on it now and added the big block that squatted the front even more. But this truck see's an occasional drag strip, street races and shows and not alot of miles of uncharted street. 4" drop is the borderline for long tube headers in my opinion.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 09-04-2015, 07:05 PM   #27
Ironangel
Ironangel's Avatar
I actually have 4-1/2" inches of clearance... Have a happy and safe weekend everybody! Off to "Greaserama!"
"Two Seventy Two's"
02 3/4 ton Express
Old 10-17-2015, 01:46 PM   #28
scoots71
Originally Posted by Ironangel View Post
Welcome to the forum Scoots! Thats a VERY good question because I have a (brand new) set of those Chevelle/El Camino BBC headers hanging on the wall because they would not clear the column shift TB350/400 linkage! Taking them to a swap meet "Greaserama" in Kansas City, this weekend...PS. $200 plus shipping, they have 45 degree vacuum/O2 sensor bungs welded to the collectors and 2 coats of VHT Flame Proof Ceramic paint in Aluminum if someone here wants them...
scoots71 is offline   Reply With Quote
Old 10-17-2015, 01:48 PM   #29
scoots71
Does anyone know if big block headers from 73 up fit in a 67-72
Old 10-18-2015, 08:29 AM   #30
BossHogg69
motor exploder
BossHogg69's Avatar
Originally Posted by scoots71 View Post
Are you guys using the stock auto shift linkage
No, I'm running a tremec 5 spd with a hydraulic clutch.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 10-18-2015, 11:34 AM   #31
scoots71
Where were they hitting at
Old 10-18-2015, 11:50 AM   #32
BossHogg69
motor exploder
BossHogg69's Avatar
they're not...
Adam
Old 10-25-2015, 07:59 PM   #33
Average Joe
Average Joe's Avatar
I realize this is an old thread but curious if anyone has used a lokar cable or rod with a column shifted automatic? I like the idea of having more ground clearance with the chevelle headers but I'd also like to keep my shifter on the column. Anyone?? -Brian
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 10-25-2015, 08:35 PM   #34
nlped
nlped's Avatar
^^^ I'm curious about this too
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 10-25-2015, 08:57 PM   #35
scoots71
Lemons makes a really nice set for a 73 up big block they don't hang below the frame I'm just not sure if they will work on 67-72 any help on this ?
Old 10-25-2015, 09:06 PM   #36
nlped
nlped's Avatar
Did you sell these? If not...I'll take them.
Carter
Old 05-05-2016, 11:32 AM   #37
hdff
hdff's Avatar
Vidman - my exhaust system looks almost exactly like yours - H pipe, black ceramic and all... Same Chevelle headers from post #9 above.
Bosshogg69 would your Hedman headers work with a stock trans brace? do the collectors come back the same distance, looking at the pic on the hedman web site the drivers side looks to be longer. I want to use chevelle headers if they will fit up with a custom exhaust and stock brace. this is what I have now. I have no idea what kind they are or what they are for but the length is great but the drivers side front tube is not right cause the PO had to cut WAY to much of the engine stand
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 05-07-2016, 12:51 AM   #38
Ironangel
Ironangel's Avatar
These headers work with the OE trans crossmember and you dont have to cut anything. They also clear the auto-trans shift linkage as well... Best bang for the buck! Amazon.com: Hedman 69110 Chevy Pu 2 & 4Wd Big... Amazon.com: Hedman 69110 Chevy Pu 2 & 4Wd Big... ...If your dead set on "Chevelle headers" then I have a brand new set of ceramic painted long tubes that will clear the mounts for $200 shipped...PM me if you want them.~Ghostrider~
"Two Seventy Two's"
02 3/4 ton Express
Old 05-07-2016, 01:50 AM   #39
hdff
hdff's Avatar
These headers work with the OE trans crossmember and you dont have to cut anything. They also clear the auto-trans shift linkage as well... Best bang for the buck! Amazon.com: Hedman 69110 Chevy Pu 2 & 4Wd Big Bloc: Automotive ...If your dead set on "Chevelle headers" then I have a brand new set of ceramic painted long tubes that will clear the mounts for $200 shipped...PM me if you want them.~Ghostrider~
Thanks but I ordered a set of Hedman mid length truck headers today, probably would have ordered the 69110 had I known but the mid's will be here Wednesday.
"Wanda"
Old 05-08-2016, 12:49 AM   #40
Ironangel
Ironangel's Avatar
Thats cool because the 110's are a long tube header that hang way down...Do you have a part number we can log for future use?
"Two Seventy Two's"
02 3/4 ton Express
Old 05-09-2016, 11:29 AM   #41
hdff
hdff's Avatar
the hedman PN I used for coated mid length headers for my Big Block is 69176. Jegs and Summit had them for the same price. i'll follow up next week when I get it back on how they fit.
Keith
"Wanda"
Old 06-10-2016, 04:15 PM   #42
AnotherWs6
AnotherWs6's Avatar
Being narrower and higher, they tucked up right underneath the horizontal pin/shaft that bolts to the frame. That shaft is what holds the part that connects the arm from the column to the part that bolts to the transmission shifter shaft. It wouldn't let the shifter rotate through the gear pattern. This may or may not be a problem with the floor shifter used in Chevelles and Caminos...? I was in a hurry to make a local car show and needed headers fast so I opted for a set of Hedman 69110's...They're long tube and hang down, but not as far as the Hookers and the Hedmans line right up with the openings in the cross member. If you have Amazon "Prime" then you can have them on your door step in 48 hours..."Win,win!" Amazon.com: Hedman 69110 Chevy Pu 2 & 4Wd Big Bloc: Automotive
The description on Amazon says they will not fit with a sway bar. Can you comment on that?
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 06-10-2016, 11:33 PM   #43
Captainfab
60-66 Nut
I don't know what the heck a front sway bar has to do with the fitment of headers ?????
Old 06-11-2016, 01:05 AM   #44
AnotherWs6
AnotherWs6's Avatar
Me neither Vernon, but there it is.
Will Not Fit Camper Special Or Vehicles Equipped With Front Sway Bar
Old 06-11-2016, 03:11 AM   #45
Ironangel
Ironangel's Avatar
My BBC 72 C-10 has the sway bar and like Captain indicated, not even close. They fit like a dream and my 396 is sitting in the front holes on 71 BB stands with small block mounts bolted to the motor...I've got pics somewhere, I'll post them up if I can find them.
"Two Seventy Two's"
02 3/4 ton Express
Old 09-04-2016, 03:52 PM   #46
scoots71
Originally Posted by Swiftshifter68 View Post
Great thread with good pic's!
I'm literally doing this same header-switch on a customer's 496cid GMC, so the larger 2" primary size is what I was after (Brodix topend + mild Comp roller valvetrain). From '67-72 2" "truck" headers to these 2" "Chevelle" headers is a savings of ~$200, the added ground clearance is a bonus. Much-appreciated on the insight! Thank you!
Old 09-04-2016, 03:56 PM   #47
scoots71
Did you find a set of headers for your 496 ?
Old 04-01-2017, 09:32 PM   #48
scoots71
Originally Posted by vidman View Post
Some pics of the same headers on my Brodix 504. Great fit
What cross member do you have for your trans
Old 06-15-2017, 11:32 PM   #49
scoots71
Great thread with good pic's! How was your clearance on the drivers side lower control arm
Old 10-23-2017, 11:47 PM   #50
Greg B
Just wanted to add some more info to this thread... I tried a set of Hedman Elite headers for 68-72 Chevelles (#68198) on my '69 stepside as well. They pretty much fit just like 68 TT's hooker headers did, but mine are 1.75" tubes. I'm using the '72 BB motor mounts and also had contact on the clamshell bracket. I already had purchased a set of Hedman Elite headers for 67-up trucks (#69820), but the hung down WAY low. Below is a pic of the truck headers on the drivers side and the chevelle headers on the pass side. BIG difference in ground clearance, since my truck is lowered. The truck headers hung down even with the bottom of the lower a-arm... The chevelle headers are dead even with the bottom of the frame rail.
BossHogg69 this is by far the best header thread I've seen especially with your pictures of both headers mounted. I chose the Hedman headers because of your detailed explanation and am waiting to get them so we can mock them up and build my 3" stainless steel system. Well done!
Greg B is offline   Reply With Quote
Thread Tools
Display Modes
