Old 08-08-2017, 07:57 PM   #1
87Skier
87Skier's Avatar
Considering a 4L60E to 4L80E swap
I've been through a few transmissions in my 96 Suburban and it's time to replace it again. So I have been considering swapping to a 4L80E. My plan was to do a semi-complete drivetrain swap and use the transmission, transfer case, and drive lines from a 3/4 or 1 ton truck/suburban from around the same year. The transmission crossmember will be moved back to match the 4L80E.
I know the plugs are the same, but not the wiring. It seems that the PCM needs to be reflashed too. I might also run into the issue of the transfer case harness being too short.
Did I miss anything? Is there anything else I should be aware of?
PS: The transmissions have different gearing and I'm willing to accept this.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
