01-18-2018, 06:11 PM | #1 |
Header gaskets
for small block ..what do you guys used that's bullet proof?
1972 Cheyenne Super..owned since 1978 1972 Surburban 4x4 1972 Cheyenne 4x4 3/4 ton.....sold 1972 Cheyenne 2wd...named Death Row |
01-18-2018, 10:15 PM | #2 |
motor exploder
Re: Header gaskets
The copper ones are the my favorite. They are also re-useable. I've used (and re-used) them on small & big blocks with no issues. The Fel-pro steel core laminates are good too and a bit cheaper than the copper ones. For a sbc, the Summit brand copper ones are like $30, the steel core laminate ones are around $20.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
01-19-2018, 09:44 AM | #3 |
Re: Header gaskets
If you use Big block length header bolts with washers almost any gasket will last a LONG time. Use the copper or laminated above as mentioned with bolts and washers the use Summits ball collector reducers that eliminate the collector gasket (about $30) and retorque after first hour of running or so and should be good for years.
01-19-2018, 12:07 PM | #4 |
motor exploder
Re: Header gaskets
x2 on the ball & socket collectors, they are the bomb!!! I use them on every header exhaust system I do know. This set is on my '69 stepper, I used the Fel Pro steel core laminate round port gaskets, the long header bolts with lock washers and it's nice & tight with no leaks.
Thread Tools | |
Display Modes | |
