06-18-2013, 03:41 PM | #26 |
Re: Project : HITCHED
quote: Once engine was dropped in the task of bolting torque converter was made much easier with the fiancé rotating engine over with me underneath.
You have a great fiancé. Supportive, gorgeous, and common interests. Congratulations to the two of you. Don't take that for granted. Not many good ones out there. About as rare as a rust free blazer. Posted via Mobile Device |
06-19-2013, 02:43 PM | #27 |
Ordered seat covers from PICKUPMAN today. Black vinyl / Orange houndstooth
06-22-2013, 12:05 AM | #28 |
moving forward i began to start routing wires to starter, alternator, coil and eliminating unused wires. to my suprise the factory harness was in excellent condition with a few wires being cracked and brittle.
06-22-2013, 07:09 AM | #29 |
Any takers on what yellow, green wires are ?
06-22-2013, 09:13 AM | #30 |
Green is usually temperature sending unit, or horn. Yellow seems to be spliced into red and red in that area could be electric choke, yellow also could go to the starter along with the purple. If infact,the red is pink(which, in gm terms, means 12 volt switched) it could also go to the starter
Follow the wires back, and make sure the colors are correct. I would change the colors back to oringinal, if they are changed. If the wires are brittle, check all the way back where they are wrapped, id replace them. Connecters are available, and part of a safety check should include your electrical harnesses Do you have a wiring schmatic, if not drop down to the electrical section, look in the stickies for a a colored one
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 06-22-2013 at 09:36 AM. |
06-22-2013, 06:22 PM | #31 |
I printed a wiring schematic from the electrical section and it was sure helpful. After doing the engine swap I have a lot less to be connected:
Coil Starter Alternator temp sensor elec choke I knew I should have labeled wires as they were removed This is another pic of the wiring. Next issue is that engine starts/idles great but falls flat as soon as rpm increases. All vacum lines are plugged/connected and it has clean fuel. Waiting for timing light to come in to check base timing. Not sure if its a little different because of the MSD diet/coil ??? |
06-23-2013, 04:30 PM | #32 |
More wires
06-23-2013, 04:35 PM | #33 |
Firewall wire harness looks to be in gret shape. No corrosion and no splices
06-23-2013, 04:40 PM | #34 |
Theres a lot of different ways to eliminate voltage regulator. Not sure what best option will be.
06-29-2013, 08:42 AM | #35 |
It wouldnt be a project if it wasnt " one step forward, two steps back " . Almost ready to move past the engine and start driving. Base timing set at 10deg, total advance 34deg, idle set at 700rpm. Starts great,idles smooth, no pinking or knocking on throttle but coughs and backfires under quick acceleration. Propane torch found the carb base gasket leaking and an increase of 75-100rpm. Almost unteaceable if it wasnt for the digital timing light. A friend lent it to me and now have to own one.
06-29-2013, 08:47 AM | #36 |
Comparing to a 72 Suburban these wires are for the emissions that mount on drivers side of intake manifold and are no longer needed. The BROWN/WHITE wire does have keyed 12V so it may come in handy once I check a few other things out. |
06-29-2013, 08:56 AM | #37 |
Checklist to complete this week:
carb intake gasket ( replace ) Lokar billet throttle/kickdown bracket ( install ) Lokar TH350 kickdown cable ( install ) wire alternator, battery, gauges, tach check coolant hoses for leaks clutch fan, shroud ( install ) mount seats, seat belts, hood power steering hoses ( install ) Then double check all fluids, check leaks ( hope none ) then test drive. |
06-29-2013, 09:01 AM | #38 |
A few clips of engine. Other than carb gasket leak and exhaust gasket donut leaking it sounds pretty good IMHO.
https://www.youtube.com/watch?v=j8NTGkwWCjs https://www.youtube.com/watch?v=oWbcBWY3DaU https://www.youtube.com/watch?v=OhtuEYiInPc |
06-29-2013, 09:20 AM | #39 |
Extra shop hands that dont mind staying late
06-29-2013, 12:08 PM | #40 |
go cyclones
Good looking dogs. You should start a thread dogs on plaid seats.
Posted via Mobile Device Last edited by JayDubBlazer; 06-29-2013 at 12:11 PM. Reason: Incorrect identification of seats |
06-29-2013, 01:26 PM | #41 |
Not plaid seat but good pic
07-19-2013, 12:49 PM | #42 |
Needs a Big Block
Great build!!
I remember the truck at Scott's. I also know that orange burb you used for reference, I'm Ryan's # parts supplier. Hahaha. Posted via Mobile Device
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
07-24-2013, 01:25 PM | #43 |
Nice Blazer!
~ It's a Learning Process ~ Click Here for my Blazer Build: 1971 Blazer 4x4 Click Here for my Work Truck Build: 1970 C10 LWB Toys: 1970 C10, 1971 Blazer 4x4, 1976 Corvette Stingray L82, 2011 Cadillac CTS 6 speed, 2008 VTX 1800F |
07-26-2013, 09:26 AM | #44 |
Progress has been steady and yesterday was the virgin run. Have to thank the help from guys in our Toyota Club, the TARSAND TOYOTAS. Its amazing how much work can be accomplished with a fridge full of beer, a few pizzas and lots of wings.
All things considered there are very minor details to workout. Engine seems to be running way to rich and is overfueling. It coughs under load and acts like an old worn out 2barrel small block. The brakes need to be bled, and rockers re adjusted but nothin major so far........ Not sure whats going on with loading pics so I will post another small vid |
07-26-2013, 11:09 AM | #45 |
07-26-2013, 11:11 AM | #46 |
Finally rescued this one for my cousin, a bit rough around the edges, body wise and is on a newer blazer frame ( 1977-87 ) but there is at least something to work with
https://www.youtube.com/watch?v=2h0T...PH10qkZ3a5fqoA |
10-29-2013, 12:55 PM | #47 |
fuel tank and repro belts
10-29-2013, 03:52 PM | #48 |
Nice, good looking pups too. I'm guessing you hunt them? My GSP is 12, but still can get out for a few hours of hunting.
10-29-2013, 07:29 PM | #49 |
the dogs get hunted for sure. After stripping the rubber from origional tank straps I replaced with rubber from outdoor floor mat and used silicone as sealant
