Old 08-24-2018, 03:55 PM   #1
2001convertable
1959 3100 4 speed gear lube weight
Hi, I have a 1959 with a 4 speed manual. I think its an sm420. Iam going on a 5 hour trip and wanted to change the gear lube before I leave. I drained it out. All I need to know is the type of lube and quantity. thank you
2001convertable is offline   Reply With Quote
Old 08-24-2018, 08:59 PM   #2
va4cqd
Re: 1959 3100 4 speed gear lube weight
75w90
should take 5.5 quarts if completely empty
va4cqd is offline   Reply With Quote
Old 08-24-2018, 11:00 PM   #3
mikebte
Can pick it up fairly cheap at a semi repair shop. I get all my transmission and gear oil at truck shops.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
mikebte is offline   Reply With Quote
Old 08-24-2018, 11:52 PM   #4
mr48chev
mr48chev's Avatar
85/90 isn't that spendy at the parts house. It takes 6-1/2 pints to fill that trans .
My ongoing truck projects:
Old 08-25-2018, 08:55 AM   #5
1project2many
Like many old transmissions, there is no input shaft seal some Muncie SM420 four speeds. The design relies on an oil slinger and LH "thread" on the input shaft to direct oil coming through the input shaft bearing onto the inside of the rear of the bearing retainer. From there oil is expected to drain back into the transmission case through a roughly 5/16" hole below the input shaft bearing. Switching to lighter base gear oil can create a fluid leak where none existed previously. Oil can work its way down the bearing retainer then end up on the flywheel and clutch disc creating a slippery mess and a truck with a slipping clutch. Having tried several different gear oils, multi-viscosity and single viscosity, I settled on 140 wt gear oil in the '57 and in my '36 Plymouth.
1project2many is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
