Old 10-24-2009, 09:56 AM   #26
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: air bags hitting the bump stops!!!!!
Originally Posted by scotts62 View Post
I used a spot weld cutter an drilled the bracket welds out and used a air hammer to knock the bracket of then ground the control arm smooth.
I did this with a 1/2" drill bit and they came off smooth
as for bump stops get a rubber freeze plug ( the temp kind that have a nut you tighen) then take the bolt out of your upper plate and use the freeze plug as a bump stop/plate bolt..I saw a pic of a guy running it and it worked well
as for me I have no bump stops and cupped LCA so my LCA lays flat against the X member..my X is about 1.5" off the ground with stock spindles
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 10-24-2009, 11:12 AM   #27
N2TRUX
Happy to be here
N2TRUX's Avatar
I suggest you build a stop. Even the best engineered system "can" fail. If your system fails and you can't roll at all, you are at the mercy of being stuck where ever you are. That's not always a good thing.
I had an exhaust system failure the in turn melted an air line. I pulled over immediately. I got out and surveyed the landscape to discover I had broke down in the middle of nowhere. To compound matters I had almost zero cell phone reception. Wow, how lucky can one guy get to break down between two towns right in the middle of a dead cell zone.
Fortunately my system allowed me to roll sitting on the bumpstops. I rolled down the shoulder for almost 5 miles to a rest stop. I was able to pull safely off of the Interstate and wait for a rollback.
Bumpstops are a good thing.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-24-2009, 11:42 AM   #28
scotts62
One day...
scotts62's Avatar
Yeah i am going to make some stops on mine too just for the same reason N2TRUX said about being able to get the thing off the road if something stupid happens.
N2TRUX- yeah that makes for a bad day and to boot with no cell phone reception been there before..
Scott
93 crew cab build
Project 62
Old 10-24-2009, 01:35 PM   #29
Hottrucks
Hottrucks's Avatar
if you have an air failure and it drags you have scrub line issues not air......I would have jacked it up put a piece of wood in there and drove it home..but thats me....
with cupped LCA and a c notch I just clear the ground with my long headers the x member is 1" off
Old 10-24-2009, 02:29 PM   #30
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Hottrucks View Post
if you have an air failure and it drags you have scrub line issues not air......I would have jacked it up put a piece of wood in there and drove it home..but that's me....
Sounds like a logical solution. That would not apply in my case for several reasons.
First off, I don't have scrub line concerns. In most cases when the system doesn't have a bump stop your tires are going to make contact with the fender liners, assuming you still have them.
Next problem is you are assuming this involved only one corner. In this scenario, I blew the supply line going to the valve block so I lost all four corners.
And last but not least, I carry extra line and fittings but this was in an area that was not readily accessible. I did have a small jack, but I did not trust it to lay under my truck while fighting a hot exhaust trying to patch the line up.
Articles-
"Refining Sierra"
Old 10-24-2009, 08:56 PM   #31
Hottrucks
Hottrucks's Avatar
if it was a supply line and it got broken and the bags where aired up it shouldn't matter..reason # 2 to keep your vavles close to your bags reason #1 would be the amount of air to charge a long line in more than a short one.....longer hoses off your tank means more storage...back in the day we would run fuel lines in a zig zag just to carry an extra gallon of fuel..sometimes thats the dif between winning and runing out
Old 10-24-2009, 09:13 PM   #32
Shane
Shane's Avatar
most solenoid-style spool valves do NOT work without back pressure ... regardless of where they are mounted
Shane is offline   Reply With Quote
Old 10-24-2009, 09:55 PM   #33
N2TRUX
Happy to be here
N2TRUX's Avatar
Kinda hard to keep your valves near your bags when your running a manifold.
You can make up all the scenarios that you wish. The bottom line is a properly designed system should be able to roll if the system fails.
Articles-
"Refining Sierra"
Old 10-24-2009, 11:01 PM   #34
kev2809
low n' slo
kev2809's Avatar
I think it all depends on what kind of truck ur building. daily driver - like n2trux said, u gotta have something there. u have more of a chance of something going wrong if u drive it everyday. on a project or weekend driver, most people probably wouldn't put one in because it looks all cluttered up in there. just my .02 cents on a bumpstump
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 10-25-2009, 09:44 AM   #35
Hottrucks
Hottrucks's Avatar
my truck had a leak on the top bunge in the air tank that would leak out all te air yet I could still get in it and the bags where full...alot of time I would fill the bags before I parked it then dump them back into the tank before I let that would refill the tank a bit so the comp didn't have to work so hard
I agree there are alot of factors to consider when building I never gave a manifold a thought all my bags have there own lines
Old 10-25-2009, 08:30 PM   #36
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Cut mine completely off also.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 10-26-2009, 07:30 AM   #37
dznucks
dznucks's Avatar
Mine will be a daily driver so I will need to fab a bumb stop.
Those of you running lower bag cups in the front, how tall are your's or howm uch did you cut them? mine are from SD and i would like to take off at least an inch.
dznucks is offline   Reply With Quote
Old 10-26-2009, 09:51 AM   #38
kev2809
low n' slo
kev2809's Avatar
I believe I read for the 67-72 1.75" tall is the lowest, for the 73-87 1.25" tall is the lowest. I was gonna cut mine down but decided I want to get 8.5" cups and recess them into the lca to get a few more inches of drop
-_--_--_ _________
Old 10-26-2009, 10:41 AM   #39
dznucks
dznucks's Avatar
kev, you mean 1.75" over all height of the cup?
Old 10-26-2009, 10:41 AM   #40
michael bustamante
michael bustamante's Avatar
Originally Posted by DZL1 View Post
I am running shocks. you just cant see from the angle picture was taken. I like my slams very much, no complaints. One other thing, I also had to cut about 3/4 of an inch of the ends of the front sway bar. when aired out, the ends would rub on the bag.
Hey Michael Bustamante, I dont see a sway bar on yours?
DZL1.
when I took the pic I had taken the sway bar of to shorten the ends just like how you said. the bag just touched the sway bar as is. Modify modify modify
1967custom
michael bustamante is offline   Reply With Quote
Old 10-26-2009, 01:02 PM   #41
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
This is a simple way to do it. Looks natural and not cluttered.
I had my bumpstop setup this way originally before I went all out on my frontend.
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 10-26-2009, 06:06 PM   #42
kev2809
low n' slo
kev2809's Avatar
that one looks good, if i run one it will probably be something like that. what bumpstop did you use?
yes, overall height of cup. i think the sd cups come like 3" tall if im not mistaken
-_--_--_ _________
Old 10-27-2009, 02:56 PM   #43
camaro__thunder
You can purchase them at Oreilly or Autozone made by Energy Suspension.
My Project 69 SWB
Old 10-31-2009, 02:37 PM   #44
kev2809
low n' slo
kev2809's Avatar
ok cool, thanks
-_--_--_ _________
Old 11-02-2009, 07:35 PM   #45
michael bustamante
looks like Im doing another parts run to o reilleys!!! thanks for the tip on those bumpstops
1967custom
Old 11-02-2009, 08:30 PM   #46
dznucks
dznucks's Avatar
thats what i got for the front and backs. i ended up cutting a step off the backs.
Old 07-19-2015, 03:29 PM   #47
crakarjax
crakarjax's Avatar
I know this is an old thread, but it doesn't look like there's any way that bumpstop would ever actually hit. Correct me if I'm wrong!
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 07-20-2015, 12:48 PM   #48
michael bustamante
My first old thread to be resurrected!! at full deflation, these stop would actually hit the
LCA. this is an oldie though. I sold this truck in 2011! it was a fun ride but i found a 67 short stepper that needed refreshing.
1967custom
Old 08-12-2015, 01:22 AM   #49
crakarjax
crakarjax's Avatar
The D2600 are 2.8" deflated and you have a plate on top, so there must have been at least 2.8" between the crossmember and LCA fully aired out, right?
