Old 12-17-2023, 11:45 AM   #1
Hotcorner
Hotcorner's Avatar
Leaf Springs on K25
I posted this in the suspension section and got crickets…
Leaf spring width question:
A while ago I ordered new FRONT leaf springs for my 1969 K2500 from Rock Auto. Now that the weather is turning bad, I was starting to get around to installing them. They appear to be the same part number from multiple vendors. They’re Husky Springs 22-384 aka Dorman 22-384. They’re a three leaf pack and the ones on my truck are only 2 leaves. But the 22-384s are narrower at the eyes. The ones on my truck are 3 1/2” at the front eye and like 3 1/4 at the rear eye. The replacement springs are significantly narrower across the leaf, i.e., 2 1/2 inches. Has anyone installed these on their 3/4 ton 4WD?
I’m not sure sure about the width? Thoughts?
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Hotcorner is offline   Reply With Quote
Old 12-28-2023, 02:13 PM   #2
AdamH.
Re: Leaf Springs on K25
I have a 68 k25 and a 71 k20. Both of them have 2.5 inch wide springs in the front.
AdamH. is offline   Reply With Quote
Old 12-29-2023, 09:38 AM   #3
That '68 came with the wider springs. In '70 the springs went to a narrower width. Guys use spacers at the spring eyes to make the later springs work on the earlier trucks
Old 12-29-2023, 10:03 AM   #4
AdamH.
Are you sure. I think the chances that a old boy changed front springs to be unlikely. Now the rears are definitely longer and wider. Not arguing just saying.
Old 12-29-2023, 10:32 AM   #5
kwmech
Completely normal. The springs should have come with bushings and sleeves to make up the difference in width
Old 12-30-2023, 10:18 PM   #6
Hotcorner
Hotcorner's Avatar
I was beginning to think that’s the case but one end of the spring has no bushing.
1969 GMC K25
Old 12-30-2023, 11:32 PM   #7
72ochre
Junior Member
72ochre's Avatar
This is the bushing kit (Energy Suspension 3.2112G) I used for the new springs on my truck. Offroad Design has some good info here https://www.offroaddesign.com/front-...gm-trucks.html.
1972 K20 350/350/205 D44 14B "Old Ochre"
2005 2500HD CCSB LS LQ4 4L80E Silver Birch
2006 2500HD CCSB LT LQ4 4L80E Silver Birch
72ochre is offline   Reply With Quote
Old 12-31-2023, 12:39 AM   #8
Hotcorner
Hotcorner's Avatar
Good stuff! Thanks!
1969 GMC K25
