Old 12-29-2017, 07:39 PM   #1
MASONGMC
2005 GMC will crank but not start any ideas
I have a 2005 GMC 1500hd will crank over but will not run.Any idea where or what I should check.Thanks
MASONGMC is offline   Reply With Quote
Old 12-29-2017, 08:58 PM   #2
greasemonkey
greasemonkey's Avatar
Re: 2005 GMC will crank but not start any ideas
Air, fuel, spark...any details on the truck like miles, maintenance, engine codes, etc would help. If it was running fine one day and not the next, I'd check the fuel pump. Usually you can hear them running to prime the system for a few seconds when you first turn the key on.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado
greasemonkey is offline   Reply With Quote
Old 12-30-2017, 04:35 PM   #3
MASONGMC
Thanks I live in Nova Scotia Canada I got water in my gas and it we had some really cold nites working good now .thanks for the reply
Old 05-16-2018, 05:04 PM   #4
dell72
I had a similar issue with my 03 2500 HD a few years back. I started it and back out of the garage to load some stuff in the bed and shut it off. Went to restart and it did nothing, no cranking or anything. My buddy who is a GM tech came over and did some testing. Turned out my ECM went bad and I had to have it towed to a GM dealer for replacement and reprogramming. Hopefully this is not your problem.
dell72 is offline   Reply With Quote
Old 05-20-2018, 08:44 PM   #5
MASONGMC
I found out what was wrong I put plugs and wires in it now it runs fine again. Should have did that first before checking everything else. thanks for your help
Old 05-20-2018, 09:33 PM   #6
RUN GMC
RUN GMC's Avatar
One thing to check is the oil pressure switch to fuel relay circuit.....they are designed not to run without proper oil pressure thus the oil pressure switch is a 3 wire setup.....a test light and a multimeter will help you figure it out.......search youtube for a "crank but no start issue" for gm truck.................
RUN GMC is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
