Old 05-16-2018, 04:35 PM   #26
Nightrider
Nightrider's Avatar
Re: 84' 3/4 lowered advice
Originally Posted by SCOTI View Post
Like jrpontiac indicated, a flip-kit can be done on the cheap by adding (welding) new leaf mounting pads under the axle tube vs. on top & using fresh/new U-bolts/nuts (don't re-use U-bolt hardware; you can re-use the original plates). But, you'll get more than 6" of drop (closer to 8" depending on how thick the spring pack is). You would need to source the pads & U-bolts for the correct OD of your axle tubes.
The shackles/hangers will get you 4" drop. You could remove some leafs to play around w/additional drop.
There is also another possibility that doesn't require welding but would require some modification (cutting, trimming, drilling, & measuring because you won't have specific instructions). You could use a 98-00 3/4 ton 8-lug flip/c-notch kit. They're similar in design. The axle tube OD should be the same (14bolt GM housings). The main difference is in the frame-rail profile but the 98-00 c-notch could be trimmed to fit where necessary.
yeah I was planning on doing the axle flip but i dont want my truck that low... so ill just do the shackles/hangers drop... do youll think this will work?http://https://www.carid.com/belltech/4-rear-shackle-and-hanger-lowering-kit-mpn-6907.html[/IMG]
] : - 71' burb,5.3,4wd
02' f350.7.3
00' F250-powerstroke
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Nightrider is offline   Reply With Quote
Old 05-16-2018, 05:08 PM   #27
SCOTI
SCOTI's Avatar
Tinydb84 provided a direct replacement shackle/hanger combo (https://www.summitracing.com/tx/part...4/applications).
Anything beyond the square body style could be different (the link you provided is for the body style AFTER the squares).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-16-2018, 05:39 PM   #28
tinydb84
tinydb84's Avatar
Here is my C20 with a 6'' drop in the rear. The front was stock height at the time.
David
Instagram: myfabguy
Old 05-16-2018, 06:45 PM   #29
Nightrider
Nightrider's Avatar
AWESOME thanks alot! so now we have the back end done... im thinking about a 2 or 3 inch spindle drop with a 1 or 2 inch spring drop so it will be 4 either way does that sound good? those are the spindles
http://www.x2industries.com/chevrole...l#.Wvy0fkxFxN7
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 05-16-2018, 06:46 PM   #30
Nightrider
Nightrider's Avatar
that looks gooooddddddd
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 05-16-2018, 07:55 PM   #31
SCOTI
SCOTI's Avatar
The rear typically requires more drop vs the front to be level. That's why you see 2/4 drops or 3/5; 4/6; 5/7 etc..... Whatever drop the rear of the truck ends up at you simply need to match the front to it. If not, there will be some rake.
I advise you to take measurements now & before taking the truck apart (now for ordering parts; before you start just to make sure nothing has changed). Take them WHERE you disassemble things so you have a solid control point in case you need to reference back to 'what you started with'. I write it all down in a little pocket notebook so I have it for reference. (and put it on masking tape @ each wheel opening for quick confirmation).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-16-2018, 08:03 PM   #32
tinydb84
tinydb84's Avatar
Scoti always has good advice. I'd follow any recommendations he has. 4/6 is a nice drop. The C20's usually have pretty tall tires so you wont look as low and you have to pay attention to your inner fender clearance.
David
Instagram: myfabguy
Old 05-16-2018, 09:03 PM   #33
manimal
manimal's Avatar
I'd be careful of some drop spindles. research the company/brand you use. I have seen PERSONALLY a few spindle stubs break off due to poor quality.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 05-16-2018, 09:38 PM   #34
Nightrider
Nightrider's Avatar
awesome. I think im going to drop the front first... then i can play the back by ear and adjust what height it needs to be..... Just trying to find the best spindles right now... should i do a 2inch or 3inch spindle?? i would love to get a 4/6 drop.. i love on the outside/country.. the roads suck so i would like to get the best spring to spindle ratio..
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 05-16-2018, 09:39 PM   #35
Nightrider
Nightrider's Avatar
ill make sure my tires wont rub
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 05-16-2018, 10:02 PM   #36
Nightrider
Nightrider's Avatar
here are two pics of my truck..
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 05-17-2018, 09:15 AM   #37
manimal
manimal's Avatar
http://www.performanceonline.com/
they sell WesternChassis spindles for a c20.
-Lance
Old 05-17-2018, 09:38 AM   #38
SCOTI
SCOTI's Avatar
IF they have them in stock. If they don't, they substitute a different brand but don't mention it. Piss poor business move IMO
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-17-2018, 10:12 AM   #39
manimal
manimal's Avatar
did not know that. Thanks. That is a crappy way to do business. Ive never personally used DJM because of all the horror stories over their Ford products.
-Lance
Old 05-17-2018, 11:25 AM   #40
Nightrider
Nightrider's Avatar
thats ****ty of them i found these...
https://www.performanceonline.com/71...e-2-half-inch/
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 05-17-2018, 11:26 AM   #41
Nightrider
Nightrider's Avatar
yeah crazy.... so what spring to spindle ratio is best??
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 05-17-2018, 01:22 PM   #42
SCOTI
SCOTI's Avatar
It just takes a call to verify they aren't substituting. They may not be for the squarebody suspension. In January, they were for the OBS/88-00 C20/30 spindles as the foundry where they get them was having issues & ceased production (their explanation).
The best spindle/spring ratio is subjective to each individual need. Using the combo of the two is usually the best approach. The deciding factors would be amount of drop & wheel choice (diameter, back-spacing/offset).
For a 4/6 on your described truck, I'd opt for a 2-2.5" spindle + trimming 1-coil from the factory springs if the truck rides decent @ the current height. Then, some combination to achieve the 6" drop on the rear. I usually opt for flip kits on C10's because IMO they're easier to install. Since flip kits on 3/4 or 1-ton trucks yield more than 6" of drop, you have to factor in what it will take to achieve/adjust to get the amount you want. Compare that to the alternatives (shackle/hanger; removing leafs; etc).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-17-2018, 01:28 PM   #43
SCOTI
SCOTI's Avatar
If they are substituting, it's not the end of the world either provided you're told. I would verify who the actual manufacturer is.
If it's Chassis Tech, research their pricing elsewhere (and their customer reviews). I canceled my order because I could get the Chassis Tech product elsewhere for cheaper yet POL (Western Chassis' daddy) maintained the same pricing as their WC brand.
Seemed to me like a 'Bait & Switch' tactic that I didn't care for so it cost them that sale (& possibly my business in the future).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-17-2018, 02:31 PM   #44
Nightrider
Nightrider's Avatar
ok i will look into that.. dang
http://www.airbagit.com/spindles-ste...pi-gm7191d.htm
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 05-17-2018, 04:10 PM   #45
SCOTI
SCOTI's Avatar
AirBagIt.com= name change from the original AIM & yet another change (Chassis Tech). Google them all to make an informed decision.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-17-2018, 10:56 PM   #46
Nightrider
Nightrider's Avatar
ok this is what ive come up with... i looked up Chassis Tech spindles and could not find any for my truck on THEIR website.... sooo i looked up the Western Chassis spindles on summit, found the ones that fit my truck and they were $462... thats to much so I kept looking and found the same ones on another website for way cheaper.. only $300
https://www.streetpros.com/product_i..._Spindles.html
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 05-18-2018, 01:00 AM   #47
manimal
manimal's Avatar
Originally Posted by scoti View Post
airbagit.com= name change from the original aim & yet another change (chassis tech). Google them all to make an informed decision.
agreed
-Lance
Old 05-18-2018, 10:35 AM   #48
Nightrider
Nightrider's Avatar
agreed
Im going to order https://www.summitracing.com/parts/d.../applications/ this weekend... Im not sure how to install the hangers because they look nothing like my stock ones... Someone explain to me how they fit? Once I figure that out Im order them...
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
Old 05-18-2018, 12:56 PM   #49
SCOTI
SCOTI's Avatar
In a nutshell.....
Secure vehicle on jack stands & verify you're safe to get under the truck (push test).
Remove the wheel, disconnect the shock & leaf spring by removing their hardware. (Do one side @ a time. Use a jack to raise/lower & hold-up the rear-end housing as needed).
Knock the rivets of the factory hangers off/out.
Align the new hangers w/the holes in the frame rails & install w/the new hardware.
Re-install the leaf pack & shock. Loosely snug the hardware for the leaf/shackle bushings but don't tighten them to spec.
Re-install wheel.
Repeat for the opposite side.
Once both sides are completed, set the truck back on the ground so the full weight is on the suspension. Tighten the leaf/shackle bushings hardware to spec.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-18-2018, 01:46 PM   #50
Nightrider
Nightrider's Avatar
In a nutshell.....
Re-install wheel.
HAHAH Thank you!
02' f350.7.3
00' Roadstar
84' Eagle model 10
72' GMC
18' camery
12' ZX14R-
