Old 08-05-2017, 12:40 PM   #1
dmw319
Thumbs down Transmission lines - HELP!
I was replacing the two lines from the transmission (th350) to the radiator and I bought these:
https://www.summitracing.com/parts/add-23-1500
It says that they come with 2x 5/16" inverted flare to -6AN male fittings and 2x 90 degree 1/4" male NPT to -6AN male fittings. The problem is that two of the fittings do not fit (the NPT ones). I should have bought the 23-1501 that comes with 4x of the 5/16" inverted flare adapters...
So without returning the hoses and getting the right set, does anyone know where I can get any adapters that are inverted flare to -6AN male? I looked online and didn't come up with much so didn't know if a different type/style would fit? Without these I am dead in the water without a vehicle and I couldnt find anything at my local part store.
Also, I'm assuming the 5/16" is referring to the hose size and not fitting size, correct? If so, are these the right ones?
https://www.summitracing.com/parts/e...6erl/overview/
https://www.summitracing.com/parts/r...SABEgIw4PD_BwE
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 08-06-2017, 11:23 AM   #2
dmw319
Originally Posted by firedemon View Post
go to your local parts store and get 5/16 steel brake lines and bend to fit
Not sure which one of my questions you are attempting to answer...
Old 08-06-2017, 12:38 PM   #3
HO455
HO455's Avatar
Re: Transmission lines - HELP!
Any good local hydraulic hose shop will have what you need. I would take your hose down with you when you go. The 5/16" refers to the size of the tubing used in the inverted flare fitting. Just be aware they make reducer style fittings. ( These are common in brake line applications. I.E. 3/16" tubing in a fitting that is sized for 1/4" inverted flare.) Its been many years since I was in Raleigh but I think there was a place called Allied hose that we used at the plant. Good luck.
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 08-07-2017, 08:41 AM   #4
dmw319
thanks for the advice!
I ordered two of these and they come tonight. hopefully they will do the trick:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 08-08-2017, 08:12 AM   #5
dmw319
post update: those 2 connectors were correct!
bad news: it didn't fix my leak. it seems to be coming from the weep hole in the bottom of the black plastic transmission cover. anyone have any ideas what that could be?
Old 08-08-2017, 08:15 AM   #6
65 GMC
Sounds like a front pump seal.
65 GMC is offline   Reply With Quote
Old 08-08-2017, 08:23 AM   #7
AussieinNC
Moderator
AussieinNC's Avatar
"Black plastic trans cover"...please post a pic so we can know exactly where you are seeing this leak...
Color of the oil leaking...red is auto trans oil...brown or black...engine oil.
If it is trans oil, it can be leaking from a couple of areas...
pump seal,
pump gasket and O ring, pump to case bolts (these should have a rubber center thin shim washer style gasket on each bolt,
convertor weld area small pin hole
All above require trans removal to correct
Could trans filler tube O ring or seal or modulator or pan gasket
If it is engine oil it could be rear main seal, sump pan gasket, oil pressure switch, manifold seals, or rocker cover gaskets.
A pic of the leak area will help us help you...
AussieinNC is offline   Reply With Quote
Old 08-08-2017, 08:25 AM   #8
dmw319
This is the piece I am talking about. You can even see the weep hole in the pic:
http://thumbs3.ebaystatic.com/d/l225...HRFAtj7CVA.jpg
It is 100% transmission fluid. It is not coming from the pan gasket, which I just replaced while I was under there.
Old 08-08-2017, 10:22 AM   #9
68is4me
68is4me's Avatar
It has to be on the tranny side then. Just like AussieinNC said, convertor seal, front pump housing seals, or pump bolt seals. No easy way to fix that, trans or engine have to be removed. I have never seen those covers in plastic I thought the were all steel.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 08-08-2017, 10:38 AM   #10
dmw319
thanks! I assume mine is some aftermarket part or something then.
Old 08-23-2017, 10:57 AM   #11
dmw319
update: had the trans rebuilt last weekend and doesn't leak a drop.
Old 08-23-2017, 01:57 PM   #12
mrein3
mrein3's Avatar
FWIW, I owned many Chevelles and a Monte Carlo before I bought my truck. I didn't know the covers were metal. Mine are all plastic. I'm guessing it is a truck verses car difference. When I swapped the 3-speed manual out of the truck and replaced it with a th350, I used what I had - plastic. The truck doesn't care.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-23-2017, 02:03 PM   #13
dmw319
yep! they replaced both the pan and cover when they rebuilt my trans.. and the new cover is plastic like my old one was.
Old 09-01-2017, 05:51 PM   #14
YoungPup1977
Is this the same transmission that you had a speedometer issue as well... rebuilding it really fixed you up.
YoungPup1977 is offline   Reply With Quote
Old 09-01-2017, 07:02 PM   #15
dmw319
Yep! That was the idea
Old 09-10-2017, 09:42 AM   #16
YoungPup1977
You spent more for the two cooler lines than a th350 transmission overhaul kit costs. I know a guy who is a great trans builder in Holly Springs, NC. He does older car/truck restorations as well. Presently, he is installing a th350 in a 1957 chevy pickup replacing the three speed manual....he charged the dude 550 bucks for the entire swap which included the trans/TC/flexplate/cooler lines/fill tube/kickdown cable and vac. line. He added a charge of 100 bucks for the CPP motor mount cross member/trans cross member. oh, yea he tossed in the starter nose for the 168 tooth flexplate, reused the old starter. no headers were added.
Not to get to nosy, how much did you spend for your th350 rebuild ?
