11-17-2017, 03:42 PM | #1 |
Can anybod ID this steering box?
It was installed by the PO, top pic is from underneath
56' 3100 shortbed |
11-17-2017, 05:18 PM | #2 |
Hollister Road Co.
Re: Can anybod ID this steering box?
looks like CPP's 400 series box conversion for 55-59
11-17-2017, 05:19 PM | #3 |
I'm pretty sure it is a modified 85/91 Toyota 4x4 box. They cut the stock brackets that go on the sector shaft housing off and trimmed it down and used a custom fabbed mount bracket. I'm thinking that someone sells a kit for it.
11-17-2017, 05:43 PM | #4 | |
Hollister Road Co.
http://www.classicperform.com/Series...eringBoxes.htm |
11-17-2017, 05:50 PM | #5 |
I knew I had seen a kit that looked like that somewhere. http://www.classicperform.com/Store/...5559PSK-OC.htm
Power steering and it drops the steering box down to clear the manifold pretty well.
11-17-2017, 09:54 PM | #6 |
Thanks guys
56' 3100 shortbed |
11-18-2017, 01:07 AM | #7 |
That should be a nice driving rig.
11-21-2017, 07:25 PM | #8 |
Not really, kinda all over road, probably go to mustang 2 and rack & pinion after driving it a few hundred miles and adjusting and re adjusting. The box is so close to the header it gets hotter than hell. I don't think I'll ever get it satisfactory with the straight axle, might as well fix it so it's enjoyable to drive. The PO installed the steering and front discs so I had to give it a try
56' 3100 shortbed |
