08-06-2017, 10:35 AM | #1 |
mechanical fan woes
so after mounting my v8 in my 51 1ton i kinda screwed up and didnt get the engine as far back as i can (can maybe get another 3/4 inch) so the mechanical fan is into the radiator, you can see in the pic i have it sandwiched in there on the left side and thats even with the pulley off. also half the fan is going to hang down below the radiator
but anyways looks like its going to be way to low anyways and the blades are going to go into the lower radiator hose if i actually bolt it up so can you even run a mechanical fan on these trucks or electric is just easier? |
08-06-2017, 10:38 AM | #2 |
Re: mechanical fan woes
pusher electric?
08-06-2017, 12:57 PM | #3 |
Looks like you need to go electric fan. Any reason you're sold on the mechanical fan? I've also seen somewhere, someone ground off those mounting plates on the side and tacked in new ones further forward to tilt the radiator away from the fan.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
08-06-2017, 01:16 PM | #4 |
looks like you are using a serpentine setup. if you have the long water pump there is a shorter pump that will give about an inch. you may need a new pulley for the water pump, since there are no ribs on the water pump pulley the original pulley may still fit the belt. (it is run by the backside of the belt)
BUT. moving the fan in may let the fan hit the crank pulley. best to do some measuring and see if you have the inch to gain. I am looking at my 4.3 serp setup as I am typing this and there is an inch there, both for the pulley and for the fan, but your results may vary. most serp systems are reverse flow water pumps, so MAKE SURE you get the right water pump. same with the fan, if you change the fan make sure the blades face the right way. I dont like the current draw and install complexity of electric fans, a mechanical fan is worth the hp hit for me. never blew a fuse on a mechanical fan.
08-06-2017, 05:37 PM | #5 | |
Hollister Road Co.
08-06-2017, 06:28 PM | #6 |
A Taurus fan seems to work for me. Brackets to hold fan in position are easy to make.
08-07-2017, 02:21 AM | #7 |
This might be the simple option but I would call and ask if it will work with your engine. Fan shouldn't stick out much more than a half inch from the hub. They do make noise though. [url]https://www.flex-a-lite.com/belt-driven-fans/15-inch-reverse-rotation-race-fan.html[/url
If the 15 inch fan clears the lower radiator hose. On a V8 that may not be an issue it was on my 250 six. You can run a spacer that allows the fan blades to clear the pulleys and still clear he radiator with room to spare.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 08-07-2017 at 02:28 AM. |
08-07-2017, 10:32 AM | #8 |
the easy solution is to get rid of the fan clutch and go with a standard fan
then make a shroud that covers the whole radiator use the top couple inches of a 55 gal or 35 gal steel barrel for the fan guard and a bit of sheet metal for the shroud
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
08-07-2017, 02:57 PM | #9 |
https://www.flex-a-lite.com/belt-dri...-race-fan.html Lets see if this link works better on the reverse rotation flex fan.
It still has to clear everything though.
08-08-2017, 01:18 AM | #10 |
Electric fan. I use a Champion radiator, their shroud, and a SPAL low profile e-fan sourced through them. I also purchased their supplied relay kit that using a sending unit in a water jacket to kick the fan on. Works perfect. 90 degree days in traffic it never gets over 180.
327 SBC. |
08-08-2017, 07:39 PM | #11 |
if it were me I would mount the rad on the front side of the support and then install an electric fan, like dwcsr suggested. a low mounted fan won't see full rad coverage. like driving with cardboard in front of the rad in the winter. may tend to run hot plus the last one I had with limited clearance on the fan ended up eating a few rads.
08-08-2017, 09:45 PM | #12 |
08-09-2017, 07:22 PM | #13 | |
ive always just liked the mechanical fans, they have always worked fine for me and i guess i just hate change. guess i was just curious if i was missing something but looks like electric is the way to go. i think i measured 3.5 inches from the radiator to the water pump pulley, so hopefully they make one that thin or ill slide the radiator upwards into the support a bit |
08-10-2017, 04:26 AM | #14 |
I want to say that's right around what my clearance was as well.
Plus side to the electric fans is HP. A standard clutch fan being the best of any fans for parasitic loss of HP still loses around 23hp. Check out this youtube video from Engine Masters on fans for info. https://youtu.be/ZXdLgaFXZzs |
09-09-2017, 09:36 PM | #15 |
After reading an article in Hot Rod or Street Rodder about fan issues - go with electric!! I had a situation that fan on 56 I am working on sat low too. Not as low as yours but did go in the lower tank area. That creates a different flow than straight thru radiator fins - and can cause a lot of fan failures - that is what the article was all about. Will actually bend the blades at higher speeds. Makes sense when you really think about it so go with a good electric fan and get the relay / temp sensor kit too.
09-09-2017, 10:32 PM | #16 |
My ex Taurus fan and shroud will blow your hair back when you open the hood. Ugly but works.
09-10-2017, 09:31 AM | #17 | |
