Old 06-17-2009, 08:28 PM   #1
easyrider
easyrider's Avatar
stock valve covers 1967 327
I have been trying to figure out what the orginial valve covers for a 67 327cu.in. engine looked like. I have chrome valve covers on my truck with pvc and oil filler plug. I am going back with the orginial intake with the oil tube in front, so I won't need the filler hole in valve cover, but I can't find a photo of the orginial ones. I've been told that it had the Chevrolet script on it and then others tell me that it was the plain valve cover with the sticker in the center saying 327 cu in. .So, can anyone set me straight once and for all??? I am needing a 4 bbl breather assy and these valve covers to bring my engine back to the orginial look. Any help will be greatly appreciated. That is the great thing about this forum... I get to pick your brains and not rely on my limited knowledge of what's what! Thanks in advance!!
easyrider is offline   Reply With Quote
Old 06-17-2009, 08:35 PM   #2
breeh
Recovering 67-72 Addict
breeh's Avatar
Re: stock valve covers 1967 327
I believe that the truck motors received the "plain valve cover". It would look cool with the scripted covers though.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 06-17-2009, 10:07 PM   #3
vectorit
What?
vectorit's Avatar
Here is a pic of my 68 327 valve cover on the passenger side, and the driver side just has a PCV towards the front.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 06-17-2009, 10:50 PM   #4
1967C20
Junior Member
1967C20's Avatar
Here is my stock engine before I did a cam, carb, and manifold swap. It is a 1967 327ci. As you can see, the valve covers are plain. The breather connects from a fitting on the back of the block to the base of the stock carb. The breather filter is in the cap of the oil filler tube. There is also a canister in the lifter valley under the intake that connects to the fitting on the back of the block. I assume the canister is a baffle of some kind so that liquid oil does not get sucked into the breather. I have photos of the whole setup if anyone is interested.
"A man's got to know his limitations." - Dirty Harry
_______________________________________________
1967 C20 Custom Camper, 327, Powerglide, PS, PB, No-Spin Locker
1967C20 is offline   Reply With Quote
Old 06-17-2009, 11:03 PM   #5
vectorit
What?
vectorit's Avatar
"1967C20" has a small journal 327.
Where as mine is a large journal 327.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 06-17-2009, 11:32 PM   #6
1967C20
Junior Member
1967C20's Avatar
You just had to bring "size" into it!
Old 06-18-2009, 02:19 AM   #7
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Brent, You mean like these? I love the gold leaf!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 06-18-2009, 10:31 AM   #8
easyrider
easyrider's Avatar
I would like to see your photos of this set up. Thanks!
Old 06-18-2009, 11:26 AM   #9
stllookn
stllookn's Avatar
I would like to see those stock pics as well. It is important from the standpoint of an accurate and correct restoration. Thanks in advance.
Old 06-18-2009, 12:39 PM   #10
1967C20
Junior Member
1967C20's Avatar
Here is the factory breather setup for '67. It is an open breather system (vents to the atmosphere instead of the air cleaner). I'm not sure what year they went to the closed system:
Here is where the PCV (yellow arrow) valve attaches to the carb base plate. The original valve screwed in the carb base plate and had a right angle fitting on it. I could not locate an original type valve so I adapted an inline valve using some brass fittings. The hose runs to a fitting on the block behind the distributor.
This is the location of the fitting:
Here is the canister inside the lifter valley. I believe it acts as a baffle:
The oil filler cap acts as a filter. Inside the cap is a material the looks like very coarse steel wool (the kind that comes in thin strips):
I hope that helps you guys out.
Old 02-22-2010, 03:52 PM   #11
gmc1971harwich
gmc1971harwich's Avatar
can u post a pic of how ur alternator mounts? im having trouble trying to mount mine. its also a 67 327 with camelhump heads, roller rockers, headers.
gmc1971harwich is offline   Reply With Quote
Old 02-22-2010, 04:54 PM   #12
michael bustamante
michael bustamante's Avatar
I think the original alternator set mounts to the ramhorns that you replaced with headers. buuut I could be wrong
1967custom
michael bustamante is offline   Reply With Quote
Old 02-22-2010, 06:43 PM   #13
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
the 327 in my 67 camaro is all original right down to the factory dated coil if it would be the same and if it would help you I could go out and take some pic's of the alt mounting and manifolds for you ?? sometimes they change stuff for car's different than truck's ,
I know that they changed to the venting in the air cleaner and went from valve pans with no holes to pans with holes in 68 (FOR CAR'S ) I'M NOT SURE WHAT YEAR THEY CHANGED THE TRUCKS ?
here is a pic I found (NOT MINE) shows the alt mounting
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 02-22-2010, 06:45 PM   #14
19673ontree
CAN'T FIX NOTHIN
here is an exellent reference photo by GM
underdash AC
Old 02-22-2010, 11:11 PM   #15
gmc1971harwich
i think my problem is that my headers force me to use an aftermarket mount. anybody else running headers run into this problem? and yea if you could take a couple pics of the upper and lower bracket mounts that would greatly help. i didnt get to take pics of it today but maybe tomorrow il take some in the day light.
Old 02-22-2010, 11:12 PM   #16
gmc1971harwich
i think i might throw my rams horn exhaust manifolds back on and ditch the headers. there crusty anyways. do i need to run a heat riser of the bottom of the drivers side manifold? or can i just leave it off.
